Dynamic Component - Need Help w/OnClick Rotation
Hi Guys:
I am trying to add the OnClick Behavior to the left and right doors of this component. The left door moves away from its hinge position when rotating. And the left door has a mind of its own. I would like one (1) door to open 90-degrees to the left and one (1) door to open 90-degrees to the right.
Kindly help! If you could set the attributes and upload the model that would be awesome! Thank you in advance!
~Susan
To change the axis, open the component, then right click on the axis, just outside the geometry, select place, and redraw axis where required
otherwise seems to work okay,
Phillip:
But of course! Lovely! Thank you SO much!
~Susan
