    Dynamic Component - Need Help
    5 Posts 2 Posters 2.4k Views 2 Watching
    • mooarchiM Offline
      mooarchi
      Hi Guys:
      I have created a dynamic component of a cabinet carcass and set the X Lens Options to: 30,45, 60, 90 & 120cm wide. As the component increases in size along the x axis, the right side panel does not align with the right side of the component. What attributes am I missing to keep the right side of the 'right panel' face aligned w/the 'door' & 'bottom' as it grows?
      Thank you in advance for solving the issue!
      Boffi_Carcass.skp
      Respectfully,
      Susan (Moses) O'Kane
      Moo Arch / Architecture & Design
      • P Offline
        pcmoor
        you need to build some relationships to position the parts
        for example
        for side panel: X =Carcass!LenX-LenX (that is the nominated measure in your drop-down minus the thickness of the part)
        • mooarchiM Offline
          mooarchi
          Hi Philip:
          Could you add the attribute then upload the model? Now the sides are growing as the component grows. I'm missing something.
          Thank you!
          Susan
          Respectfully,
          • P Offline
            pcmoor
            Cheers
            Boffi_Carcass (1).skp
            • mooarchiM Offline
              mooarchi
              Thank you Philip! Really appreciate you taking the time to help me out!
              ~Susan
              Respectfully,
