Dynamic Component - Need Help
Scheduled Pinned Locked Moved Dynamic Components
5 Posts 2 Posters 2.3k Views 2 Watching
    mooarchi
    Hi Guys:
    I have created a dynamic component of a cabinet carcass and set the X Lens Options to: 30,45, 60, 90 & 120cm wide. As the component increases in size along the x axis, the right side panel does not align with the right side of the component. What attributes am I missing to keep the right side of the 'right panel' face aligned w/the 'door' & 'bottom' as it grows?
    Thank you in advance for solving the issue!
    Boffi_Carcass.skp
    Respectfully,
    Susan (Moses) O'Kane
    Moo Arch / Architecture & Design
      pcmoor
      you need to build some relationships to position the parts
      for example
      for side panel: X =Carcass!LenX-LenX (that is the nominated measure in your drop-down minus the thickness of the part)
        mooarchi
        Hi Philip:
        Could you add the attribute then upload the model? Now the sides are growing as the component grows. I'm missing something.
        Thank you!
        Susan
        Respectfully,
          pcmoor
          Cheers
          Boffi_Carcass (1).skp
            mooarchi
            Thank you Philip! Really appreciate you taking the time to help me out!
            ~Susan
            Respectfully,
