    Same command on multiple entities at once
    5 Posts 4 Posters 380 Views 4 Watching
    • A
      Assafro
      I was wondering if there is some plugin, module or other way to select multiple entities at once, and then do a certain command on them at the same time in stead of doing it one by one.
      Especially when it comes to push-pulling or offsetting faces, it would be a major time saver.
      Thanks in advance πŸ˜‰
      • T
        TECHDAVE02
        Double click on a face then hold shift and click on the face. Or to be sure to get a deselect hold shift + ctrl (work well for offset)
        • A
          Assafro
          That just results in a selection of the face's edges right?
          I meant doing an offset or push-pull, at the same time, while multiple (non-touching or adjacent) faces are selected.
          Whenever I select multiple faces, and then press the offset or push-pull button, my selection is lost.
          • BoxB
            There are various tools to do what you want depending on the exact result you are after.
            A few that spring to mind are
            Fredo's Joint Push Pull, which can manipulate many entities at the same time.
            SDMitch Multiple offset
            Tig's Smart offset
            • cottyC
              cotty
              Or you can use components to "copy" your editing...
              like in this example screencast...
              my SketchUp gallery
