    One-shot toolbar buttons?
    11 Posts 3 Posters 815 Views 3 Watching
      slbaumgartner
      Is there a way to create a button in a toolbar that works like the zoom extents button? That is, when you click it the underlying Tool/Command does its one-shot action and then the Toolbar button returns to un-selected? The only way I've been able to get this effect is to force the model to select the SelectionTool (which isn't necessarily what was active before). I tried things such as popping the active tool, but it didn't reset the button.
      Steve
      • Dan RathbunD Offline
        Dan Rathbun
        A button should never show it is checked unless YOU set it's validation to anything other than MF_ENABLED || MF_UNCHECKED
        Answer yes, using send_action.
        IF there is a selection then this Zoom command should zoom to the selection, otherwise zoom to the model extents.
        command_proc = {
          if Sketchup.active_model.selection.empty?
            Sketchup.send_action("viewZoomExtents;")
          else
            Sketchup.send_action("viewZoomToSelection;")
        πŸ’­
        I'm not here much anymore.
        • tt_suT Offline
          tt_su
          That is the default behaviour, unless you implement validation procs or make the button activate a tool. When you activate a tool the button will remain pressed for as long as that tool is active.
            slbaumgartner
            @dan you may have missed my point. I don't want to implement a zoom, I was just mentioning zoom extents as a tool whose button does what I want. I have a different tool that isn't really modal, it just performs an action and then wants control to go back to whatever was live before.
            @TT I'm puzzled. Here's what I tried:
            tb=UI;;Toolbar.new "Test"
            cmd = UI;;Command.new("clickme") {puts "click!"}
            tb.add_item cmd
            tb.show
            This works functionally, that is, it prints click! in the Ruby Console, but the button toggles between unselected and selected ("pressed") look with each click. I want it to reset to unselected after each click and reactivate whatever was the active tool before the click.
            Steve
              Dan Rathbun
              Your example works fine for me on PC, in both versions that I have installed (and from memory in all versions I have ever had installed.)
                Dan Rathbun
                You may have run into a Mac bug in a certain version.
                Try this:
                cmd.set_validation_proc { MF_UNCHECKED }
                tb.add_item cmd
                tb.show
                  slbaumgartner
                  Try this:
                  > tb.add_item cmd
                  > tb.show
                  Tried that in several versions of SU and the button toggles between "unpressed" and "pressed" every time...
                    Dan Rathbun
                    Disable all plugins, test again. If still it does not work.. log a bug report.
                    State whether the toolbar is floating, docked vertically, or on the top horizontal bar (which has always been buggy on the Mac.)
                      Dan Rathbun
                      Also verify that MF_UNCHECKED == 0, just to be sure no plugin has messed with the global constants.
                        slbaumgartner
                        Still doesn't work, whether floating, docked, or in the top bar. Filing a bug.
                        Steve
                        • tt_suT Offline
                          tt_su
                          Oh, right - yes I noticed that there's a bug under OSX. Sorry, I mostly use PC so I'd forgotten. I think there's an issue for it, but I'll check again and bump it.
