One-shot toolbar buttons?
Is there a way to create a button in a toolbar that works like the zoom extents button? That is, when you click it the underlying Tool/Command does its one-shot action and then the Toolbar button returns to un-selected? The only way I've been able to get this effect is to force the model to select the SelectionTool (which isn't necessarily what was active before). I tried things such as popping the active tool, but it didn't reset the button.
Steve -
A button should never show it is checked unless YOU set it's validation to anything other than
MF_ENABLED || MF_UNCHECKEDAnswer yes, using send_action.
IF there is a selection then this Zoom command should zoom to the selection, otherwise zoom to the model extents.
command_proc = { if Sketchup.active_model.selection.empty? Sketchup.send_action("viewZoomExtents;") else Sketchup.send_action("viewZoomToSelection;") end }
That is the default behaviour, unless you implement validation procs or make the button activate a tool. When you activate a tool the button will remain pressed for as long as that tool is active.
@dan you may have missed my point. I don't want to implement a zoom, I was just mentioning zoom extents as a tool whose button does what I want. I have a different tool that isn't really modal, it just performs an action and then wants control to go back to whatever was live before.
@TT I'm puzzled. Here's what I tried:
tb=UI;;Toolbar.new "Test" cmd = UI;;Command.new("clickme") {puts "click!"} tb.add_item cmd tb.showThis works functionally, that is, it prints click! in the Ruby Console, but the button toggles between unselected and selected ("pressed") look with each click. I want it to reset to unselected after each click and reactivate whatever was the active tool before the click.
Steve -
Your example works fine for me on PC, in both versions that I have installed (and from memory in all versions I have ever had installed.)
You may have run into a Mac bug in a certain version.
Try this:
tb=UI;;Toolbar.new "Test" cmd = UI;;Command.new("clickme") {puts "click!"} cmd.set_validation_proc { MF_UNCHECKED } tb.add_item cmd tb.show -
Try this:
tb=UI;;Toolbar.new "Test" > cmd = UI;;Command.new("clickme") {puts "click!"} > cmd.set_validation_proc { MF_UNCHECKED } > tb.add_item cmd > tb.showTried that in several versions of SU and the button toggles between "unpressed" and "pressed" every time...
Disable all plugins, test again. If still it does not work.. log a bug report.
State whether the toolbar is floating, docked vertically, or on the top horizontal bar (which has always been buggy on the Mac.)
Also verify that
MF_UNCHECKED == 0, just to be sure no plugin has messed with the global constants. -
Still doesn't work, whether floating, docked, or in the top bar. Filing a bug.
Steve
Oh, right - yes I noticed that there's a bug under OSX. Sorry, I mostly use PC so I'd forgotten. I think there's an issue for it, but I'll check again and bump it.
