    One-shot toolbar buttons?
    11 Posts 3 Posters 866 Views 3 Watching
    • Dan RathbunD
      Dan Rathbun
      A button should never show it is checked unless YOU set it's validation to anything other than MF_ENABLED || MF_UNCHECKED
      Answer yes, using send_action.
      IF there is a selection then this Zoom command should zoom to the selection, otherwise zoom to the model extents.
      command_proc = {
        if Sketchup.active_model.selection.empty?
          Sketchup.send_action("viewZoomExtents;")
        else
          Sketchup.send_action("viewZoomToSelection;")
      πŸ’­
      I'm not here much anymore.
      • tt_suT
        tt_su
        @slbaumgartner said:
        Is there a way to create a button in a toolbar that works like the zoom extents button? That is, when you click it the underlying Tool/Command does its one-shot action and then the Toolbar button returns to un-selected?
        That is the default behaviour, unless you implement validation procs or make the button activate a tool. When you activate a tool the button will remain pressed for as long as that tool is active.
          slbaumgartner
          @dan you may have missed my point. I don't want to implement a zoom, I was just mentioning zoom extents as a tool whose button does what I want. I have a different tool that isn't really modal, it just performs an action and then wants control to go back to whatever was live before.
          @TT I'm puzzled. Here's what I tried:
          tb=UI;;Toolbar.new "Test"
          cmd = UI;;Command.new("clickme") {puts "click!"}
          tb.add_item cmd
          tb.show
          This works functionally, that is, it prints click! in the Ruby Console, but the button toggles between unselected and selected ("pressed") look with each click. I want it to reset to unselected after each click and reactivate whatever was the active tool before the click.
          Steve
          • Dan RathbunD
            Dan Rathbun
            Your example works fine for me on PC, in both versions that I have installed (and from memory in all versions I have ever had installed.)
            • Dan RathbunD
              Dan Rathbun
              You may have run into a Mac bug in a certain version.
              Try this:
              cmd.set_validation_proc { MF_UNCHECKED }
              tb.add_item cmd
              tb.show
                slbaumgartner
                Try this:
                > tb.add_item cmd
                > tb.show
                Tried that in several versions of SU and the button toggles between "unpressed" and "pressed" every time...
                • Dan RathbunD
                  Dan Rathbun
                  Disable all plugins, test again. If still it does not work.. log a bug report.
                  State whether the toolbar is floating, docked vertically, or on the top horizontal bar (which has always been buggy on the Mac.)
                  • Dan RathbunD
                    Dan Rathbun
                    Also verify that MF_UNCHECKED == 0, just to be sure no plugin has messed with the global constants.
                      slbaumgartner
                      Still doesn't work, whether floating, docked, or in the top bar. Filing a bug.
                      Steve
                      • tt_suT
                        tt_su
                        Oh, right - yes I noticed that there's a bug under OSX. Sorry, I mostly use PC so I'd forgotten. I think there's an issue for it, but I'll check again and bump it.
