    Shade umbrella???
    28 Posts 9 Posters 3.3k Views 9 Watching
    • utilerU
      utiler
      Hey guys, I've seen somewhere a thread about making a commercial type of shade sail structure but can't recall the name of the post....
      Any ideas?
      Just Curious...
      • U
        unearthed
        Ferrari is your tool, link has download as tool is hard to find:
        http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=32380
        if that fails go here:
        http://rhin.crai.archi.fr/rld/plugin_details.php?id=768
        Source is here some where but page hard to navigate:
        http://en.sergeferrari.com/furniture-design/
        if it's just a sun umbrella you need I have a nice one on file, just PM me.
        Growplan - People ∩ Plants ∩ Place
        windows 7 64b, 4GB RAM, SU 8.0.16846
        Gimp, QGIS, Vectorworks 12, Bricscad 11
        • utilerU
          utiler
          Thanks Nigel, I used to use SSB but when curviloft came along I started using that. Have seen Ferrari plugin too but haven't really tried it. I just recall seeing a thread about wanting to model something similar and didn't subscribe to it.... 😳
          What I'm wanting to model is two 10.0m x 8.0m pyramid type shapes joined together along the 8.0m side. Square sides with concave sides meeting at a small domed apex.... Maybe I'll try to find an example of what I mean.
          Just interested in various methods people would attack it. 👍
          Just Curious...
          • BoxB
            Anything like this?
            http://sketchucation.com/forums/viewtopic.php?f=335%26amp;t=55059
            • gillesG
              gilles
              What about this one:
              http://sketchucation.com/forums/viewtopic.php?f=335%26amp;t=55059#p499764
              • utilerU
                utiler
                Thanks guys, both posts one in the same. I can see how Ferrari could do it but I'm trying to do it with current tools I use; I'm sure there is a way.
                Below are some examples of what I'm hoping to achieve:
                SHADE IDEAS.pdf
                Also a skippy file of some base shapes:
                Shade.skp
                I'm keen to see some different ways to achieve this.
                Just Curious...
                • utilerU
                  utiler
                  working through it a little more here is what I think the shapes should look like:
                  Shade.skp
                  Just Curious...
                  • utilerU
                    utiler
                    So here's progress but not how I want the outcome...
                    I thought I may have to create segments of the fabric and make them components seeing each side will be the same however when I do that I end up with hard edges where my shapes connect.
                    Its really got me beat how you do this. Maybe I should be creating it from the ground up rather than around the edges...?
                    Shade.skp
                    Just Curious...
                    • pbacotP
                      Screen Shot 2014-02-06 at 8.39.13 PM.pngIDK how to do this for the precise mathematics but you get a different shape if you have a curve at the bottom edge. Not sure this is what you are after.
                      • jeff hammondJ
                        jeff hammond
                        a square perimeter with a rounded top and a drooping mesh using curviloft would be something like this:
                        tent_su6.skp
                        dotdotdot
                        • gillesG
                          gilles
                          This how Ferrari deals with it, for info.
                          • mitcorbM
                            mitcorb
                            Hi:
                            I fiddled with this yesterday. I did it two ways. When I did the deed by sections, selecting each curve in sequence, and mirror copied the result, I noticed the mis-shapened circular opening. When I selected everything and then activated the tool, I got a more regular opening. Segment count and size of segments in the curves do matter for more regular surfaces, as well as degree of curvature. My "good" result still had too much torsion/warpage in the finished surface. Did you see this too?
                            • utilerU
                              utiler
                              @pbacot said:
                              [attachment=0:2noo5rgt]<!-- ia0 -->Screen Shot 2014-02-06 at 8.39.13 PM.png<!-- ia0 -->[/attachment:2noo5rgt]IDK how to do this for the precise mathematics but you get a different shape if you have a curve at the bottom edge. Not sure this is what you are after.
                              Thanks for giving it a go, mate! Normally I would expect the outer edge to be exactly how you've done it but the client wants to be able to fit drapes to the edges to close it in at times.... 👍
                              Just Curious...
                              • utilerU
                                utiler
                                [attachment=1:2w6zx0be]<!-- ia1 -->tent_su6.skp<!-- ia1 -->[/attachment:2w6zx0be]
                                [attachment=0:2w6zx0be]<!-- ia0 -->tent.jpg<!-- ia0 -->[/attachment:2w6zx0be]
                                That's pretty much how I had attempted it also, Jeff however the 4 'hips' will actually be welded and stretched so they won't appear to have hard edges....
                                cheers for the input though! 👍
                                Just Curious...
                                • utilerU
                                  utiler
                                  That's close, gillies although the surface on the outside of the apexes differ from the inner. seems 'warped to one side.
                                  Getting close though! 🎉 🎉
                                  Just Curious...
                                  • utilerU
                                    utiler
                                    @mitcorb said:
                                    Hi:
                                    Thanks Tim, what tool did you use?
                                    Just Curious...
                                    • BoxB
                                      I'm not really sure about what shape it is you are after but this is Extrude edges by rails.
                                      I don't know how you work white on white? sends me blind.
                                      • jeff hammondJ
                                        jeff hammond
                                        soften the edges after arraying. (or gap the array at the hips and fill in with an actual rounded surface)
                                        the main point being- if you use that outwardly bulging edge of the top ring as part of a networked surface and the opposing edge is straight, the bulge is going to carry throughout the surface.. if you want the surface to sag in the middle, you'll have to do something like i showed (if using curviloft or any of the 2rail sweep plugins)..
                                        maybe with soap skin& bubble you could get the sunken results as it has the pressure adjuster..
                                        dotdotdot
                                        • mitcorbM
                                          mitcorb
                                          @utiler:
                                          I used Curviloft by activating the "tent" icon.
                                          • utilerU
                                            utiler
                                            So this is where it ended up at but still not convinced its the best result.
                                            Just Curious...
                                            • 1 / 2
