    Is There a Plugin which do that ?
    5 Posts 4 Posters 465 Views 4 Watching
      TheBone
      Hello Community .
      I've wondered if there is a PlugIn which can do that :
      http://img4.bilder-hochladen.tv/kl6xD6oj.png
      And that around the complete circle .
      I guess there is a Plugin which can do that but i forgot the name of it .
      If somebody can help me it would very helpful.
      Greetings
      Tbone
      Im sorry for posting it at the Plugin section , while writing that i had the idea that a Topic can be created where Users can ask if (the Plugin what he is searching for is already existig )
      • gillesG Offline
        gilles
        • ctrl I guess.
          Gilles beat me to it... πŸ˜’
          Use the native tool ?
          Select one 3d-form [best if it's a component ?].
          Activate the Rotate tool + Ctrl to start Copy mode.
          Pick the circle's center as the rotation's anchor=point and then set the copy's angle by two picked vertex-nodes of the same circle.
          One copy is made at the new angular rotation...
          Now immediately type 12x + <enter> ]or however many copies you want... you can type 12**x** or 12*****]
          Multiple copies are now arrayed around the circle, using the original angular spacing.
          An alternative is to pick the whole swept-angle for the first copy, and then immediately type **/**12 and then more copies will fill in the space between the original and the 'end' copy, again these are evenly arrayed, with the angles calculated for you...
            TheBone
            Thanks , its also working on this way .
            Thanks guys
            • JQLJ Offline
              JQL
              Alternatively you can use "Component stringer" plugin if it happens you want to do that in a different set of lines or a curve.
              www.casca.pt
              Visit us on facebook!
