    Runtime Error
    3 Posts 2 Posters 370 Views 2 Watching
    • Mistro11M
      Mistro11
      Hi. I been using Sketchup for a few years now and I never experienced this error before. Usually my Sketchup runs smooth, specially since I learned to use the openGL and purge regularly. I notice lately that it is running slower than usual. Like a lot of lag when moving the view around.
      Then suddenly I got this and Sketchup shut down
      Does anyone know why this would happen?
      Structural Integrity is Not Just Physical...It's in the Design and Purpose
      • mitcorbM
        mitcorb
        Hi, Mistro:
        I looked around and found an older thread in this link:
        https://groups.google.com/forum/#!topic/sketchupissues/gN4yhIK3tGY
        Is it indeed your graphic card settings?
        • Mistro11M
          Mistro11
          @mitcorb said:
          Hi, Mistro:
          Thanks mitcorb! It's funny because I found that same thread earlier and remembered I never set my graphic card settings after my last reformat. But still not sure if that is the cause because I reformatted months ago and did many Sketchup projects since with no problem. But then again, I recently did a windows update so maybe something got reset? When I went in the Nvidia control panel it was on "let the 3D application decide". So I set it to high quality instead so applications will use the card settings and Sketchup is running more smoothly.
          If it happens again, I will report it here.
