    Dimension text rendering
    layout
    5 Posts 2 Posters 832 Views 2 Watching
    • B
      Boiseux
      Hello,
      I'm totally stuck on this issue :
      I do all my dimensioning in sketchup because i want the dimensions to be dynamic with the model.
      Now, when i insert my scenes in layout, some viewports render correctly, but others do not render just the dimensions text. It seems to (NOT ALWAYS) happen when i ajust the scale or viewport size.
      Dimensions always render OK when i use raster rendering but thats really not suited to my work (2D elevations and section views).
      Could anybody help me on this ? THANKS !
      Frans
      • K
        kaas
        Are you experiencing the same problem as I described here: http://sketchucation.com/forums/viewtopic.php?f=14%26amp;t=53556
        • B
          Boiseux
          Yes that's it, but i would say it doesn't even depend on how large the scale is.
          Did you find a solution ever since ? I see your post is dated from 2009 !
          Frans
          • K
            kaas
            The post is dated Jul 30, 2013 (I joined SketchUcation in 2009).
            The bug is still alive and kicking I'm very sad to say. Still hoping it gets fixed in the next release...
            • B
              Boiseux
              Thanks for your answers, even if i hoped it was not a bug.
              Frans
