How to copy an object in XYZ by using scale in DC. ??
HI,
Once again Stuck in half way I have created an object in DC I succeed in copying in X,Y. Direction but fail to do in Z-Direction.
So can someone give me any calculation or formula or any reference DC Model..
...."I want an create DC object which can be copied in all 3 direction XYZ."
I will attached the file what i did.
Regards,
Shaan
ITS A Bit Urgent Can someone Reply soon
Wooo i have done It .....
HI, tell us how you did it
I dont know if I realy understoud your problem... but there is a solution for a 3D matrix in DC
DareDevil, thank you
Register LoginAdvertisement
