    Cannot reset file association after SU 2013 install
    22 Posts 7 Posters 2.8k Views 7 Watching
    • sketch3d.deS Offline
      sketch3d.de
      Registry:
      HKCR\SketchUp.Document\shell\open\command\(Standard);<short_name_path_to_sketchup>
      Norbert
        jpin
        @mgfranz said:
        I currently run SU Pro 8, I wanted to trial run SU 2013, my OS is Win 7 64. By default my .skp files are all associated with SU 2013, but I want to change the default program to SU 8 however no matter what I try to do they always open with 2013. I have done the Open>Default Program route, I have gone through the registry and changed the default path to C:\Program Files (x86)\Google\Google SketchUp 8, but when I double click on a .skp file it still opens with 2013. When I right click and try to change the Open With>Browse> and select Google 8/SketchUp.exe the only option I get it 2013.
        So the only way I can open a .skp in SU 8 right now is to open the SU 8 program from the Desktop or Start and manually locate the file I want to open, is there a way to change the path in Win 7 or do I have to just uninstall 2013?
        I have faced the same problem and have also looked for a solution here before. As there was no simple fix. I uninstalled the 2013 version.
        Only to find out today while reinstalling SU 2013 that during installation of SU 2013 if you clear the check boxes for creating new file associations in Windows for skp files, then windows lets sketchup 8 remain as the default application for skp files.
        Try that, it is so far working for me.
        Hope it works for you as well
        • 2 / 2
