    Dark Sci-Fi/Apocalyptic door.
    8 Posts 6 Posters 958 Views 6 Watching
    • Rafferty94R Offline
      Rafferty94
      Modeled in SketchUP and then exported to Blender to UV map and texture. I realise that the open door on the right should not open that way and instead should open outwards.
        Rafferty94
        No feedback 😞?
          Bump is a bit strong.
          • tademaT Offline
            tadema
            Hello Scot, as Rich says the bump is far to strong! Also it's confusing because it looks like a set of emergency exit doors on a building although the title leads you to believe it's going to be something you would expect on a spaceship.
            Maybe a closer view of only one pair of doors?
            John
              Rafferty94
              Thanks for the suggestions Rich and John.
              The door would be grounded so to speak and would not be on a spaceship etc. I'm building assets that will populate my scene, Which will be a "Dark Sci fi/ Apocalyptic building.
              I had the idea from emergency doors but these have been reinforced with the plating you can see in the picture.
              Adjusted the normal map.
              • david_hD Offline
                david_h
                would a Dark Sci-Fi/Apocalyptic door have panic bars on it? I'm thinking. . the inhabitants probably wouldn't want you to be able to get out.
                jus' spit-ballin' here.
                although they are those old style Panic bars that probably don't meet code anymore, so they are kinda scary. πŸ’š
                • sfto1S Offline
                  sfto1
                  In the first posted image , the pair on the right looks like the door is swinging in, and the exit/panic devices are too pristine for anything remotely "dark". In an apocalyptic landscape, I'm imagining hardware that would probably be hanging off the door with a seriously pitted or corroded finish.
                  Happy modeling.
                  • ken28875K Offline
                    ken28875
                    Hi Scott,
                    I agree with the others' feedback.
                    Here are my suggestions:
                    • You doors are cool, but maybe they are too simple and have a "boring" shape/outline (simple rectangle). Try to make them more interesting by breaking the shape with angles.
                    • Same idea for the details of the inside of the doors. Instead of being horizontal, the plating can be tilted and mixed with crazy shapes at different angles, especially if you want to convey the feeling of dark and apocalyptic (read: chaos).
                    • The handles should follow the same design. Maybe bend them and mix them with curved or angled bars.
                    I have attached some samples of sci-fi doors I did in the past.
                    Hope these helps. I look forward to see more assets.
                    Cheers!
                    _KN
                    Follow Your Dreams.
