    30 x 42 paper size
    layout
    23 Posts 9 Posters 8.8k Views 9 Watching
      jlyon
      I use 30 x 42 paper in my practice. It's not listed as a choice in File/document setup/paper. Is there a way to create this size and add it to the drop down list?
      • pbacotP Offline
        I am not sure about windows. In Mac I'd just open page setup and choose another paper size. Add border or other setups then under File-- choose save as template.
          It would be the same thing on the PC. You can create custom templates for any size you want.
          • FrederikF Offline
            Frederik
            30 x 42cm is equal to International paper size A3...
            The accurate size is 297 x 420mm...
            Size A3 certainly is one of the standards you can select... πŸ˜‰
            Cheers
            Kim Frederik
              I figured since Mr. Lyon is on my side of the pond, he was referring to inches not cm. Perhaps I was incorrect. πŸ˜‰
                jlyon
                Got it. Thanks
                  sonder
                  Yes, 30"x42" is E size in US. I stopped using this size as the contractors hate it in the field. I only use D size now (24" x 36").
                    chadgould
                    We have done some 30x42 sets and there are a few things that we learned. If using raster images, these end up being some pretty chunky drawings, especially if you like the higher quality setting. We had to break the set up into smaller groups of pages to keep the files moving along at a reasonable working pace. Also, if you are exporting PDF files from these big pages it helps get the export to work if there are fewer pages in each file.
                    good luck!
                    Chad
                      cursor
                      From my experience at Hercules Aerospace in UT (late 70s through most of the 80s), E-sized drawings were/are 34"x44". Yes, they were in fact quite difficult to manage ... both in the office and for field personnel.
                      Personally I prefer formats that fold neatly to fit a letter-sized format (8Β½"x11"). 22"x34" (ANSI D) works great. πŸ’š
                      • KrisidiousK Offline
                        Krisidious
                        E is normally considered engineering size... For land surveying, large civil projects etc. You should always use standard sizes. Unless it's something special.
                        By: Kristoff Rand
                          sonder
                          E size in U.S. is standard at 30"X42". D size is 24"x36". E size is a total pain in the field. D is much more manageable. These days I just use my iPad in the field.
                            Krisidious
                            Oh I don't use it... unless, it's for some massive house that I would have to go 1/8" on... Because if there's anything contractors hate more than E size... it's 1/8 scale. πŸ˜‰
                            I always use D...
                            By: Kristoff Rand
                            • pbacotP Offline
                              I've resorted to 1/8" scale plans and then partial plans of 1/4" scale in some cases. It takes a lot of setup and checking.
                              Since I am doing almost all house plans lately. Maybe 1/4" scale D size should be the most house people need!
                              Same on the last hotel project I worked on. There we often saw half-sized prints being used on site, the sets having so many sheets.
                                Krisidious
                                Cursor, the original poster is asking in regards to architecture, which in the US uses E as 36Γ—48. And by saying you should always use standard sizes, that standard would of course be relevant to one's profession and location. But... You should always use standard sizes unless it's just something one off. Standards are the bread and butter of drafting and design. It keeps everyone on the same page so to speak.
                                I've always considered 36x48 to be standard because when printing off the roll you have 36inch wide paper rolls on the printer. This allows you to print D & E with ease by simply rotating your print job.
                                But, I wasn't going to argue with Nick... He's an architect and you don't argue with architects. I wondered why he and the poster were asking about an odd size. I've never seen 30x42 and thought that was the point of the whole conversation, that it was a custom size.
                                By: Kristoff Rand
                                  Krisidious
                                  I was being facetious... I have argued with many as well. And I have been fired because of it on at least one occasion.
                                  I wasn't taking anyone's side...
                                  And we don't know what you know, because you have not shared it in your profile or in this forum. The truth is we don't know you at all, You may well be a 12 year old having fun, but from your manner of speech I highly doubt it... Hopefully you'll rectify that by posting more often and sharing some of your knowledge with the rest of us.
                                  By: Kristoff Rand
                                    cursor
                                    I didn't mean to rock anyone's boat.
                                    I specifically suggested a couple of days ago that some introductory venue might be offered for new members of the forum to introduce themselves (although I joined in 2008, I have not at all been active), but I just got jokes as feed-back.
                                    In short, I have worked in engineering and architectural circles since 1968. I'm NOT some 12 year old. Hell ... my grandson just turned 20 years old. As a matter of fact, my daughter's 40th birthday is exactly today!
                                    Perhaps we could share more, later ... at some more appropriate place/time. This thread is about standardized paper formats, after all.
                                    If you want to limit the standards, then at the very least recognize:
                                    • E sized architectural format is 36"x48" (not 30"x42")
                                    • E1 sized architectural format is 30"x42"
                                    I will remind you that for 40+ years (as hinted in my previous post) Hercules Aerospace has/had assumed the 34"x44" format ... in pencil, in ink, and on mylar or vellum. I used all of those media ... using T-square & triangles, Hamilton mechanical rising drafting tables and coupled drafting arm solutions, etc.
                                    Actually, the same 34"x44" E format was recognized by the very largest privately owned engineering company in the world β€” Fluor Engineers and Constructors (Irvine CA) β€” for whom I worked for three years. But hell, what did I know at the time (at the age of 22-25) about standardized media formats. What did Nick Sonder know at that time?
                                    I can actually supply a photograph of me working at such a manual workstation (in 1975). Warning ... my hairline has receded some. I guess that doesn't matter since you don't have a clue what I look like now! LOL
                                    Kind Regards
                                    [ c ]
                                      cursor
                                      Standards certainly very, don't they. I thought that to be a major point of mine.
                                      Actually, while I have great respect for what Nick Sonder has offered (particularly in terms of SU/LU structure), his statement regarding paper standards seemed inaccurate.
                                      I have argued with many an architect, over any number of issues (some are more informed than others ... like engineers, like auto mechanics, like ... whomever), and I won't hesitate in the future (especially when their statements are patently wrong). I recently spent no less than $5,600 on the advice of a licensed architect ... who admitted to me that she couldn't "visualize space in 3D." Yeah, my bad. So ... paper-size issues should be a minor issue. The facts are there. Don't take offense, and don't take arbitrary sides based on some professional preference. (You don't, afterall, have a clue about what I do, nor about how such might trump or lay shallow to Mr. Sonder's.
                                      Truth is, there are standards. And they are very many.
                                      Here, we're talking about paper standards. I can handle that. I can also handle 3D visualization/design.
                                        sonder
                                        Oh Jeez! Argue with me anytime. Cursor is correct. E1 is considered the standard large format size used in architecture, but around here, we never referred to it as E1. We all call it E - incorrectly obviously. It is 30x42. Architects rarely if ever go to the large format E at 36x48. If I ask my printer to print on "E" size, I will get 30x42; At least here in my neck of the woods. Not that it really matters to me, as I never use larger than D size. If the home is too large for the sheet I simply create a key plan at 1/8", then show partial plans at 1/4.
                                        Any E size doesn't fit well on a tailgate! I think in another 10 years, there won't be any paper in the field. At least I hope so!
                                          Krisidious
                                          Kind Regards
                                          [ c ]
                                          if there's an air plane on that table I'd love to see...
                                          By: Kristoff Rand
                                            cursor
                                            Beyond E, E1, E2, and E3, there are sizes F through N. Most are not anymore employed.
                                            • 1 / 2
