    Warped surface
    9 Posts 4 Posters 795 Views 4 Watching
      raedy07
      hello,
      can sketch-up draw 'warped surfaces', like for example a ships' hull ?
      thanks,
      RJ
        Yes. Do a search here on the forum for 'ship', 'boat', 'hull', etc. You'll find plenty of examples.
        • cottyC Offline
          cotty
          And you can have a look at these plugins (and there are many others):
          • Curviloft
          • Extrude Tools
          • Artisan [trial]
          my SketchUp gallery
            raedy07
            hi all! a year has passed, i'm making another attempt.....
            do i need the PROversion to install 'curviloft'?
            are there any available plugins with HYDRODYNAMIC functions? able to calculate volume, immersion etc of a vessel?
            • cottyC Offline
              cotty
              No.
              my SketchUp gallery
                raedy07
                ok, i downloaded curviloft. is there a tutorial, somewhere? found 1 or 2 on u-tube, but not much of a help. having troubles to get started.....
                • cottyC Offline
                  cotty
                  You should have a look at Fredos videos in the plugin topic:
                  http://sketchucation.com/forums/viewtopic.php?p=248195#p248195
                  my SketchUp gallery
                    I believe there only Plugins for volume by Tig, by SDmitch
                    Better to see these links and import your model inside some free ones! πŸ˜‰
                    Delftship free is a good one! β˜€
                      raedy07
                      thanx Cotty, i can do it 1 way now
