    Retrieve size sketchup file using ruby
    7 Posts 3 Posters 584 Views 3 Watching
    • G Offline
      glro
      The idea is to prevent sketchup from crashing when a plugin is called on a model the size of which is too big for the computer capacity
      by showing an error message before the plugin is effectively launched
      i didn't find anything in "model info" SU ruby API concerning the file size
      is there a way using ruby?
        The File.size( filePath ) returns the specified file's size in bytes.
        So if your code gets the SKP model.path and it's not empty, then you can get the size of that SKP...
        Then do what you want with it...
        model = Sketchup.active_model
        path = model.path
        unless path.empty?
          size = File.size( path )
          UI.messagebox("This SKP is #{size} bytes !")
          ### or whatever...
        • G Offline
          glro
          OK
          i didn't find this information in
          http://www.sketchup.com/intl/en/developer/docs/methods.php
          nor
          http://www.sketchup.com/intl/en/developer/docs/classes.php
          Thank you, your code works
          As long as the path doesn't contains "é" or "è", or characters like that
          Using french and meters while programming sketchup, makes it more difficult...
          Impossible to detect problematic characters in a path, since ruby answers "Run aborted (error has occurred)" and stops...
            The problems with accents in File paths and SketchUp's current Ruby on PCs are well know.
            It is a 'PITA' 😲
            Until a better version of Ruby is used by SketchUp [ 🎉 ] for now you could try encoding the path - but it is an unreliable pain...
            ### get 'path'
            if $KCODE=="UTF8" ### what is yours ?
                begin
                  upath = path.unpack("U*").map{|c| c.chr }.join
                rescue
                  upath = path
              end#if
            ### Then do 'File' operation on the encoded string...
            exist = File.exist?( upath )
            size = File.size( upath )
            ### etc
            • G Offline
              glro
              Yes, it is UTF8
              For now, i shall use the code like this
              begin
              unless path.empty?
                ### or whatever...
              rescue
              UI.messagebox "problematic characters in the file path"
              return
              thank you
              • tt_suT Offline
                tt_su
                nor
                Those docs only cover the SketchUp API, refer to the Ruby docs for core Ruby features: http://www.ruby-doc.org/core-1.8.6/index.html
                • G Offline
                  glro
                  nor
                  I am not a professional programmer, and sometimes, i even surprise myself when i get a result from the code i just wrote
                  there is intelligence in the code itself
                  Maybe that's why i enjoy so much writing code
                  Next time i don't find something in SU API, i'll look for it in Ruby doc
                  Thank you
