    Spiral Path in Mound...
    3 Posts 3 Posters 517 Views 3 Watching
    • J
      jcorreiadefreitas
      Hey guys,
      Have been trying to create a spiraled path up a simple eliptical mound (originally drawn in cad)
      i can create the mound using from contours (top and bottom ellipse)... the only thing i can do aftewards is drape it....
      i think im looking for a hybrid between a drape and a stamp (the path needs to conform to the mound but keep itself straight and level)
      Any thoughts on the best way to approach this?
      Sketchup drape
      CAD
      • ely862meE
        ely862me
        I think that if you select the outer edges and pull them up you will have a straight and leveled path. Try this and see what happens.
        Or after you get just one line intersected with the cone you could use Follow me and keep plugin to create the path.
        Elisei (sketchupper)
        Come and See EliseiDesign
        • KrisidiousK
          Krisidious
          this would do it in seconds...
          404 Not Found
          (www.valiarchitects.com)
          By: Kristoff Rand
