    Follow the color lines
    6 Posts 3 Posters 343 Views 3 Watching
    • E
      erzane
      sometimes my component refuse to follow the blue, red or green line when I move it
      today I have problems to move it down (on the blue line direction, it goes everytime in the other colored lines direction..
      is it a key for tell to cpu to follow the direction of our choice ?
      thanks
        It sounds to me as if your component has gluing attributes and is glued to the red/green plane. Change the attribute to remove the gluing and you should be able to move it in any direction.
        You could post the SKP file.
        • E
          erzane
          correct
          I just right cliked ''modify axes'' and I see only red and green ones 😕
          must I explode it or can I modify it like this ?
            Right click on the component in the component window and choose Properties.
            • BoxB
              Right click and select unglue.
              • E
                erzane
                perfect!!
                thanks 😄
