    [Plugins] TIG-PointOff v1.0 20131120
    2 Posts 2 Posters 2.3k Views 2 Watching
      (c) copyright 2013, TIG
      All Rights Reserved
      THIS SOFTWARE IS PROVIDED "AS IS", WITHOUT ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING WITHOUT LIMITATION, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      Usage: Plugins menu > TIG-PointOff
      Pick a point, you are asked to enter a distance offset from that point.
      A number is taken as current model-units but you can add a units suffix too, so
      if you are working in mm you can use 1100 or 1.1m to distance the cpoint etc.
      You can also select the Axis of offset X Y Z - default is Z [up]
      A cpoint is added at that given offset [use -ve values for opposite vector].
      The last used distance is remembered during that session.
      Repeat as desired...
      Press <space> or choose another tool to stop.
      It undoes each added cpoint in turn.
      Version:
      1.0 20131120 First release.
      Download from the SketchUcation PluginStore
      http://sketchucation.com/resources/pluginstore?pln=TIG-PointOff
      or AutoLoad it from the SketchUcation Plugin Store dialog within SketchUp itself http://sketchucation.com/resources/plugin-store-download
        Very particular thing! πŸ˜„
