    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 143.0k Views 85 Watching
    • P Offline
      pgarmyn
      @caronte01 said:
      Hi Piet,
      Great news, it works on the mac!!!!
      Well, most of it. The console still shows some errors, and it is very slow(core2duo macbook from mid 2010), compared to my work pc (Core I7). Probably has to do with logging.
      I can update an existing rich section, and I am currently creating a new one, but it is veeery slow (projection depth default should not be no limit, ....it makes rs veeery slow). Also, parameter change sort of works, but it will not update changes directly. The section has to be manually updated after closing the dialog.
      Legend creation works
      Info, does not work, it stops expecting start, but no indication on how to (enter, double click, right click)
      What else should I check?
      Great work!!!!
      S
      [attachment=0:1sf5tz6w]<!-- ia0 -->log.txt<!-- ia0 -->[/attachment:1sf5tz6w]
      I'll keep testing
      You can try out without logging (RichSection/Settings >> file & console >> No), and switch only on for debugging if errors occure.
      I still have to make some more videos:
      • projection : for most, it can be swiched of; it make sense for plan view (i use it to show the beams under the next floorslab in grey pointed lines)
      • info : select the tool, a RichSection sectionplan (or the sectiongroup), and than (without shift) a group or componentinstance of your model. An info panel should explain which sectionmaterial was or will be applied, and why it was applied.
      • update on/off : only for moving, turning the sectionplan; for model changes : still manual update
        What else to test : use it and report what sequences don't work (error, crash, not as espected)
        About the spanish translation : you can do it in the excel file (without testing, and send it to me) or the .rb file (notepad, you can test). Keep a copy of the original rb : a missing \ or " will prevent the plugin to start.
        Thanks for reporting and translating
      • KrisidiousK Offline
        Krisidious
        For some reason I'm not getting the faces of the section. The section cuts, it adds the projection but no faces.
        By: Kristoff Rand
          bimbachi
          @pgarmyn said:
          What did produce the crash? .... What is the output in the ruby console?
          crash probably related to complex "projection"
          this is ruby just after new restart of skp:
          RS0.4.3|0.567|Logging to RubyPanel : true
          RS0.4.3|0.005|Logging to File : false
          RS0.4.3|0.001|PiGaRSection.userFileLocations MAC : /Users/tignaciuk/Library/Application Support/SketchUp 8/Sketchup/Materials
          RS0.4.3|0.001|RSdefaultRSMats /Users/tignaciuk/Library/Application Support/SketchUp 8/Sketchup/Materials/RichSection-v0.3/#default.mat.skp : true
          RS0.4.3|0.001|Start loading lang files : /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/PiGa_RichSection/
          RS0.4.3|0.001|proc loadlang :
          RS0.4.3|0.001|loadlang EN : /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/PiGa_RichSection/RichSectionLangEN.rb
          RS0.4.3|0.001|loadlang file exists : true
          RS0.4.3|0.003|Nesting:[] :
          RS0.4.3|0.001|Nesting:[PiGa::RSection] :
          RS0.4.3|0.001|language loaded : EN
          RS0.4.3|0.002|Define context menu :
          RS0.4.3|0.001|Define toolbar + menu :
          RS0.4.3|0.003|rsMenu.add_item(:RS_menu) : #Sketchup::Menu:0x12402bb4
          RS0.4.3|0.001|rsMenu.add_item(cmdCreate) : 50346
          (eval):2837: warning: parenthesize argument(s) for future version
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2.rb:19: warning: already initialized constant PLUGIN_ID
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2.rb:20: warning: already initialized constant PLUGIN_NAME
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2.rb:21: warning: already initialized constant PLUGIN_VERSION
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb:16: warning: already initialized constant VERSION_PATTERN
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/sketchup.rb:21: warning: already initialized constant COLOR_GL_POLYGON
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/sketchup.rb:25: warning: already initialized constant COLOR_ALPHA
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/sketchup.rb:29: warning: already initialized constant RAYTEST_WYSIWYG
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/system.rb:16: warning: already initialized constant PLATFORM_IS_OSX
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/system.rb:19: warning: already initialized constant PLATFORM_IS_WINDOWS
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/system.rb:22: warning: already initialized constant TEMP_PATH
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/window.rb:23: warning: already initialized constant THEME_DEFAULT
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/window.rb:24: warning: already initialized constant THEME_GRAPHITE
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/window.rb:31: warning: already initialized constant EVENT_WINDOW_READY
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/window.rb:43: warning: already initialized constant EVENT_CALLBACK
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/window.rb:70: warning: already initialized constant EVENT_OPEN_URL
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:27: warning: already initialized constant BB_LEFT_FRONT_BOTTOM
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:28: warning: already initialized constant BB_RIGHT_FRONT_BOTTOM
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:29: warning: already initialized constant BB_LEFT_BACK_BOTTOM
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:30: warning: already initialized constant BB_RIGHT_BACK_BOTTOM
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:31: warning: already initialized constant BB_LEFT_FRONT_TOP
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:32: warning: already initialized constant BB_RIGHT_FRONT_TOP
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:33: warning: already initialized constant BB_LEFT_BACK_TOP
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:34: warning: already initialized constant BB_RIGHT_BACK_TOP
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:36: warning: already initialized constant BB_CENTER_FRONT_BOTTOM
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:37: warning: already initialized constant BB_CENTER_BACK_BOTTOM
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:38: warning: already initialized constant BB_CENTER_FRONT_TOP
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:39: warning: already initialized constant BB_CENTER_BACK_TOP
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:41: warning: already initialized constant BB_LEFT_CENTER_BOTTOM
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:42: warning: already initialized constant BB_LEFT_CENTER_TOP
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:43: warning: already initialized constant BB_RIGHT_CENTER_BOTTOM
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:44: warning: already initialized constant BB_RIGHT_CENTER_TOP
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:46: warning: already initialized constant BB_LEFT_FRONT_CENTER
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:47: warning: already initialized constant BB_RIGHT_FRONT_CENTER
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:48: warning: already initialized constant BB_LEFT_BACK_CENTER
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:49: warning: already initialized constant BB_RIGHT_BACK_CENTER
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:51: warning: already initialized constant BB_LEFT_CENTER_CENTER
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:52: warning: already initialized constant BB_RIGHT_CENTER_CENTER
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:53: warning: already initialized constant BB_CENTER_FRONT_CENTER
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:54: warning: already initialized constant BB_CENTER_BACK_CENTER
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:55: warning: already initialized constant BB_CENTER_CENTER_TOP
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:56: warning: already initialized constant BB_CENTER_CENTER_BOTTOM
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:58: warning: already initialized constant BB_CENTER_CENTER_CENTER
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:59: warning: already initialized constant BB_CENTER
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:64: warning: already initialized constant MB_ICONHAND
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:65: warning: already initialized constant MB_ICONSTOP
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:66: warning: already initialized constant MB_ICONERROR
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:67: warning: already initialized constant MB_ICONQUESTION
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:68: warning: already initialized constant MB_ICONEXCLAMATION
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:69: warning: already initialized constant MB_ICONWARNING
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:70: warning: already initialized constant MB_ICONASTERISK
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:71: warning: already initialized constant MB_ICONINFORMATION
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:72: warning: already initialized constant MB_ICON_NONE
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:74: warning: already initialized constant MB_DEFBUTTON1
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:75: warning: already initialized constant MB_DEFBUTTON2
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:76: warning: already initialized constant MB_DEFBUTTON3
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:77: warning: already initialized constant MB_DEFBUTTON4
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:82: warning: already initialized constant MESH_SHARP
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:83: warning: already initialized constant MESH_SOFT
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:84: warning: already initialized constant MESH_SMOOTH
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:85: warning: already initialized constant MESH_SOFT_SMOOTH
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:90: warning: already initialized constant POINT_OPEN_SQUARE
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:91: warning: already initialized constant POINT_FILLED_SQUARE
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:92: warning: already initialized constant POINT_CROSS
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:93: warning: already initialized constant POINT_X
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:94: warning: already initialized constant POINT_STAR
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:95: warning: already initialized constant POINT_OPEN_TRIANGLE
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:96: warning: already initialized constant POINT_FILLED_TRIANGLE
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:114: warning: already initialized constant VERSION
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:118: warning: already initialized constant PREF_KEY
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:121: warning: already initialized constant PATH
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:122: warning: already initialized constant PATH_LIBS
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/TT_Lib2/core.rb:125: warning: already initialized constant PATH_LIBS_CEXT
          (eval):344: warning: don't put space before argument parentheses
          (eval):444: warning: don't put space before argument parentheses
          (eval):666: warning: don't put space before argument parentheses
          (eval):1221: warning: don't put space before argument parentheses
          (eval):1403: warning: don't put space before argument parentheses
          (eval):1627: warning: don't put space before argument parentheses
          (eval):2702: warning: don't put space before argument parentheses
          (eval):2703: warning: don't put space before argument parentheses
          (eval):2824: warning: don't put space before argument parentheses
          (eval):2845: warning: don't put space before argument parentheses
          (eval):935: warning: don't put space before argument parentheses
          (eval):936: warning: don't put space before argument parentheses
          (eval):939: warning: don't put space before argument parentheses
          (eval):943: warning: don't put space before argument parentheses
          (eval):1520: warning: don't put space before argument parentheses
          (eval):2496: warning: don't put space before argument parentheses
          (eval):2498: warning: don't put space before argument parentheses
          (eval):2531: warning: don't put space before argument parentheses
          (eval):2533: warning: don't put space before argument parentheses
          (eval):2973: warning: don't put space before argument parentheses
          (eval):2983: warning: don't put space before argument parentheses
          (eval):2994: warning: don't put space before argument parentheses
          (eval):3004: warning: don't put space before argument parentheses
          (eval):3102: warning: don't put space before argument parentheses
          (eval):3129: warning: don't put space before argument parentheses
          (eval):3138: warning: don't put space before argument parentheses
          (eval):3143: warning: don't put space before argument parentheses
          (eval):3220: warning: don't put space before argument parentheses
          (eval):3223: warning: don't put space before argument parentheses
          (eval):3226: warning: don't put space before argument parentheses
          (eval):3268: warning: don't put space before argument parentheses
          (eval):3269: warning: don't put space before argument parentheses
          (eval):3324: warning: don't put space before argument parentheses
          (eval):3325: warning: don't put space before argument parentheses
          (eval):3506: warning: don't put space before argument parentheses
          (eval):4556: warning: don't put space before argument parentheses
          (eval):4635: warning: don't put space before argument parentheses
          (eval):4997: warning: don't put space before argument parentheses
          (eval):5052: warning: don't put space before argument parentheses
          (eval):5096: warning: don't put space before argument parentheses
          (eval):5100: warning: don't put space before argument parentheses
          (eval):9026: warning: don't put space before argument parentheses
          (eval):9026: warning: parenthesize argument(s) for future version
          (eval):191: warning: don't put space before argument parentheses
          (eval):291: warning: don't put space before argument parentheses
          (eval):758: warning: don't put space before argument parentheses
          (eval):906: warning: don't put space before argument parentheses
          (eval):692: warning: don't put space before argument parentheses
          (eval):699: warning: don't put space before argument parentheses
          (eval):719: warning: don't put space before argument parentheses
          (eval):739: warning: don't put space before argument parentheses
          (eval):746: warning: don't put space before argument parentheses
          (eval):766: warning: don't put space before argument parentheses
          (eval):786: warning: don't put space before argument parentheses
          7
          key = Units
          value = 0.0
            bimbachi
            (mac) same for me, it apears only after manual update
            • P Offline
              pgarmyn
              For SU 8 and Mac, you need the last test version. It will become the next official version.
              http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=55072%26amp;start=210#p522628
              You can switch off logging in the settings.
              Still problems?
                Krisidious
                Yes, that's the version I'm on.
                By: Kristoff Rand
                • P Offline
                  pgarmyn
                  Can you send me the log file after ...
                  • In a NEW model.... (Not opening an existing model)
                  • create a closed box
                  • group it
                  • select the tool 'RichSection creation' ( the most left on the RichSection toolbox)
                  • create a section through the unique group (important : wait until the plugin has finished : see ruby console)
                  • copy and post the log file (when opening Sketchup, a panel tells you where the log file will be created )
                    Krisidious
                    actually that did produce a face with a material in the section.
                    is a "solid" required for sectioning?
                    here's the log file.
                    RichSection_log.txt
                    By: Kristoff Rand
                    • P Offline
                      pgarmyn
                      is a "solid" required for sectioning? ...
                      As explained in the first post :
                      Elements don't have to be solid, but only closed sections will generate section-materials.
                      ( and solids alwys produce closed sections)
                        Krisidious
                        This is what I get on a simple structure or complex for that matter.
                        By: Kristoff Rand
                          caronte01
                          HI Kristoff,
                          Can you post that model?
                          S
                            Krisidious
                            sure...
                            0000.skp
                            By: Kristoff Rand
                              caronte01
                              In your rs settings, section was off (the first item on the list). Also, some of the groups/components in your model were non solid.
                              From my experience, rs works better with solids. I use tt's solid inspector a lot. RS works well with nested solids, and even with multi mesh solids (something native su solid tools has problems with).
                              Things to avoid:
                              Ungrouped geometry.
                              Dividing lines on coplanar faces, except when they are used to separate different materials.
                              Santiago
                              0000.skp
                                Krisidious
                                Thanks for the help Santiago, I did have "Yes" selected when I created the section. as for the solids and such no.
                                By: Kristoff Rand
                                  caronte01
                                  Hi Piet,
                                  Some screenshots of the dialog boxes, win vs. mac. I´ve highlighted in red the clipped text. I tried shortening some of those lines, but the dialog would resize, and clip other text. It also happens in the english translation...
                                  Config
                                  Settings
                                  Legend
                                  del
                                  • P Offline
                                    pgarmyn
                                    Hi Santiago
                                    Good job ❗
                                    I will report this to the sketchup team and the community!
                                    See : http://sketchucation.com/forums/viewtopic.php?f=11%26amp;t=57642%26amp;p=524309#p524309
                                    Thanks !
                                      caronte01
                                      Hi Piet,
                                      Three small things.
                                      Can default settings be saved, at least per session? I´m creating several rs on a model, I´m changing some of the settings from the default (rs profile lines to yes, so I can snap to the rs in layout, and projections to off) I have to do this every time I create an rs. Seems simple, but if I forget, and leave projections on, it takes forever to create an rs.
                                      It would be great to have esc abort the rs creation/update. Right now, the only way I´ve found is to either leave rs running, or force quit sketchup....
                                      In the settings dialog, move RSName to the top... Right now it is not easily found, down at the bottom.
                                      Cheers,
                                      Santiago
                                      • P Offline
                                        pgarmyn
                                        Hi Santiago
                                        • about settings saved: i planned to propose the last used settings in creation, except name, section on/off and projection on/off, but i can limit the exception to the name...
                                        • escape : very usefull (was planned), but more difficult : Have to rewrite a lot. Will have to find the time.
                                        • name on the top : ok
                                          Thanks for the suggestions
                                          caronte01
                                          Thanks!
                                            caronte01
                                            Hi Piet,
                                            Do you have a new version available? The current demo version expired yesterday....
                                            Thanks!
                                            santiago
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 19
                                            • 20
                                            • 12 / 20
