    Vanishing Point Grids and Tools
    2 Posts 1 Posters 1.3k Views 1 Watching
    • U
      universalstonecutter
      Searching for more information a on using Photoshop vanishing point grids and measuring tool.
      they are handily to make quick "scaled" & "rectified" textures from grids in perspective.
      Vanishing points grids are Cartesian grid of equal-sided squares. Measurements of the grid can be adjusted to any scale based on a known image in the photo
      Prespective grids of 3d wall of a building can be rendered to photoshop. Linking the grid layer with the original photo, the grid can be rectified using photo shop tools.
      Anaylsis tools cab be used to measure images in 2d and perspective.
      ====== any interest in helping creating a pdf
      Close-Range Photogrammetry -
      goal is to provide a suite of tools for architectural close-range photogrammetry for use in archaeological research.
      Modeling a Buliding in 3D using “Sketchup" and Photoshop “ Vanishing Point tools1. Close-Range Photogrammetry
      Have potential benefits of a tool that can extract relatively accurate measurements from photographs taken by non-metric cameras are enormous.
      universalstonecutter2003@yahoo.com
      Dennis Dickens
      • U
        https://www.pinterest.com/pin/349732727295659055/
        Vanishing Point Filter tools export Vpe files to Sketchup - Creates 3d models
        any grid(s) created in vanishing point can be exported in VPE format - Vanishing point exchange -
        the export results in a series of files - a geometry data file and a rectified png image for each grid created.
        This Vanishing Point export option is the reverse of the the process of pasting a rectified image on the clipboard into any grid perspective plane drawn .
        Example Russel Brown video " Ribbon of Perspective" shows the process of pasting an image into vanishing point grid and the image can be move between perspective grids and non perspective while maintaining the same scale factor.
        apply VPE export to his file will give the reverse process - perspective grids will be exported as rectified grids.
        The rectified grids can be imported into skectchup to create a 3d Model
        rVanishing point option import option can be used to transfer grids a complete 3d Model - only skectup problem is the axis point in sketchup has to be changed.
        Exporting and rectifying Vanishing Point Grids -, VPE format - has not got a tutorial on this feature- Why? the information is only discussed on Photoshop (Vanishing point grids exchange) and affect effects.
        Vanishing point export tools can be exported as 3d model - even transfer to photoshop 3d app. or Skectchup
        Summary: photoshop perspective grids can be exported as scaled rectified image files - duplcating the Phot Match feature in trimble sketchup Research Photoshop vpe file and other 3d model formats.
