    Scale Factor Plugin?
    9 Posts 5 Posters 1.1k Views 5 Watching
    • deaneauD Offline
      deaneau
      Hello@All
      could anybody guide me how i can insert a scale factor?
      ok i build objects 1:1
      how i can insert the scale like 1:160, 1:87 etc.
      i would build models for real.
      look here to understand what i search
      http://en.wikipedia.org/wiki/HO_scale
      is there a plugin to enter this ?
      0k i could enter for 1:160 --> 0,00625
      or 1:87 --> 0,01149425
      1:87 go faster and this scale i can better hold in my head.
      thank you
      dean
      MADE, BORN AND LIVING IN BERLIN
      Big Thank You to all Programmers
      Some German words are so long that they have a perspective. M.Twain
      • cottyC Offline
        cotty
        A quick way would be:
        • draw a line 87 (cm, m, inch, ...) and
        • use the tape measure tool to change the model scale for this line to 1 (cm, ...)
        my SketchUp gallery
          ArCAD-UK
          You have a Pro licence, this is what Layout does - Insert your model and set the scale. Unless of course you need the model scaled for 3D printing?
            If you need your SketchUp models scaled down for 3D printing, I would do as Carsten suggests and use the yellow Tape Measure tool to do the resizing. You can either use a temporary line drawn in the model space or scale some known dimension.
            I've done paper models of buildings for model railroads. Here's an example:
            http://farm6.staticflickr.com/5087/5355804283_aaf9ed2243_z.jpg
            I unfolded the building in the lower left corner to get the image, below. I inserted that as a viewport into Layout which I scaled to suit my son's N-scale railroad. Then I made a PDF file and had it printed on some heavy card stock. This part is all more easily done in LayOut and then the model could be printed at any scale.
            http://farm6.staticflickr.com/5047/5356417176_1c6b05956e_z.jpg
            I added tabs to my final design although they don't show here.
            • deaneauD Offline
              deaneau
              papercraft is cool... im not sure... i had seen a plugin here... like unfold.
              i would love do have both a plugin for papercraft and 3d printing.
              papercraft for lowcost or lowbudged and 3d printing for models on the Table.
              @ cotty du bist ein scherzkeks πŸ˜‰--cotty youre a joker.
              a plugin will be faster and my deadline is not a problem than.
              i have never print in 2d and 3d. is the result really acceptable?
              @ dave. a model railroad was ever i big wish for me as a kid. however we have had only a sleepingroom and livingroom. the coal cellar was to small and dusty and the garret open for all renter.
              i play sometimes with railsimulator on PC πŸ˜‰ you see my dream is now reality...vitual reality πŸ˜„
              edit: http://sketchucation.com/forums/viewtopic.php?f=323&t=27528&hilit=papercraft#p238568
              regards dean
              • BoxB Offline
                Cotty is not joking with you.
                  Indeed! Cotty is not joking with you. And his method with the Tape Measure tool would be every bit as fast as a plugin. Learn what the native tools can do before you ask for plugins to do the same thing.
                  • cottyC Offline
                    cotty
                    not really πŸ˜‰
                    my SketchUp gallery
                    • deaneauD Offline
                      deaneau
                      cotty you are my hero..that works... i had never known this function.
                      @dave you are right.
                      thanks at all
                      and thanks to dave, Don't trouble your head about it. πŸ˜‰
                      dean
