    Trying to connect/bridge two faces
    6 Posts 5 Posters 482 Views 5 Watching
    • P
      Pipcard
      So I'm trying to connect two faces with the pencil tool. (Red lines were added in MS Paint)
      http://imageshack.us/a/img713/7651/dyd3.png
      Trying to connect the lines in front results in this:
      http://imageshack.us/a/img138/3961/ys06.png
      Is there any way to fix this
        So you just want the rail across the top? There are several things you can do. You could make groups or components of the uprights and draw the rail in between. You could draw rectangle on the face of one upright and use Push/Pull to pull it into a rail. You could also draw in the lines manually as you've started to do and just delete the unwanted face. Exactly what you do will depend on what you need out of the model and what you have already drawn.
        • Rafferty94R
          Rafferty94
          If the lines are on an axis then just use the PushPull feature from one end to another
          • cottyC
            cotty
            There is nothing to fix. If you draw a coplanar closed loop of edges, SketchUp will always create the face for them. If you don't need it, you can delete it. If you deleted one face by mistake, you can redraw one of those edges and the face will be generated again.
            my SketchUp gallery
            • P
              Pipcard
              Yeah, I just selected the unnecessary face and pressed the delete key.
              Before, I was trying to use the eraser tool, which only worked on edges.
                And if you want use some useful Plugins (after mastered the classic tools) πŸ˜„
                try the Didier Bur Projection where the last icon can extrude a line(s)! β˜€
                Of course you can move draw them in any 3D angle direction! πŸ€“
                So any junction will be a game's boy! πŸ˜‰
                If you move all edges of a plane surface(s) that is an "open Tube" Push Pull Multiple with a direction! β˜€
