    Orbiting problem
    3 Posts 3 Posters 279 Views 3 Watching
    • Z
      zsolt67
      Sometimes the models disappears when I orbiting.
      What I am doing wrong?
      • BoxB
        It's called Clipping, if you do a search for clipping it will give you a bunch of threads full of reasons and ways to fix or avoid it.
          It's the well known clipping thing.
          There are a few different causes.
          You're in Parallel Projection--switch to Perspective view, hit Zoom Extents and then go back to Parallel Projection if you wish.
          You're model is a long distance from the origin or there is some geometry at a long distance from the origin. Keep you model close to the origin.
          Hit Zoom Extents. Does your model get smaller with a bunch of empty space? That empty space contains some stray geometry that needs to be deleted.
