    [Plugin] FaceSplit v1.0.3
    44 Posts 18 Posters 30.2k Views 18 Watching
    • G Offline
      glro
      @renderiza said:
      [b]glro:
      That would be very cool indeed! I think there is a plugin that does something like this but don't remember it just now. If I find it will let you know. 👍
      Maybe you think also to voxelize.rb
      http://sketchucation.com/forums/viewtopic.php?t=36063
      but voxelize makes cubes only; it would be funny to split the volume in exact sub-volumes, and try to build the whole volume back again, using sketchup
      i have a 3d connexion mouse, and there is a game like this, to learn how to use it
      and in addition, splitting a volume in sub-volumes is equivalent to building a 3d mesh, for structural analysis...
      • renderizaR Offline
        renderiza
        @pixero said:
        I have this idea to be able to split a face with inner loops like windows by projecting lines in the direction of the edges to the outer loop.
        This is excellent idea! It will produce the cleanest geometry possible before dividing it even more. 👍
        The plugin I had in my mind was not voxelize...it was one that only worked if you had SketchUp Pro.
        Anyways making a plugin like this would be cool indeed. Not sure if I possess the knowledge to do it myself at the moment but will see if I can experiment with the idea in the future.
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
          renderiza
          [pre:3p20mm78]Authors:: Anar | Dan Rathbun | Pilou | Renderiza | TIG
          Plugin Name:: FaceSplit
          Version:: 1.0.1
          Date:: 10/28/2013
          Cost:: Free[/pre:3p20mm78]
          FaceSplit v1.0.1 is now available for download.
          http://s18.postimg.org/6mnop92dl/split_dlg.png
          Note: Will eventually make video explaining how to use plugin.
            Sure a video will give some ideas to users! 😄
            What are the natures of the up date ?
            http://sketchucation.com/forums/download/file.php?id=111403
            • guanjinG Offline
              guanjin
              我点击图标,没有任何反应!
              I come from China, is to learn
              • cottyC Offline
                cotty
                @guanjin said:
                我点击图标,没有任何反应!
                You should click after you have selected one or more faces.
                my SketchUp gallery
                • guanjinG Offline
                  guanjin
                  @cotty said:
                  @guanjin said:
                  我点击图标,没有任何反应!
                  I have tried。
                  Thank you
                  • 1 Offline
                    120711014
                    thanks for sharing~~~~~~~~
                    • U Offline
                      Ulimann
                      I have tried but no success,to get this plugin to work.I have reinstalled a few times!
                      Running SU 8 Pro on Windows 7.
                      Any suggestion to get it working?
                      • erikBE Offline
                        erikB
                        same here.
                        also SU8 pro and win 7 (64)
                        I also think I have all the administrator rights set on every subdirectory.
                        Strange, I can see the icon but can not click on it nor can I change the number.
                        erikB
                          renderiza
                          Uploaded another version to Plugin Store please download it and try to see if it works. The last version used HTML5 to play sound and that might of caused the plugin not to work with people that didn't have latest Internet Explorer version installed.
                          Download Internet Explorer Here.
                          If that didn't solved it please let me know...Thanks! 👍
                          Note: If anyone finds error on 'Ruby Console' please let me know. Here is how to get that information... Open it on 'window>Ruby Console' and then try running Canvas. If Ruby Console detects anything it should show up in window.
                          • erikBE Offline
                            erikB
                            I am a firefox user, but updated IE with link above,... and it works !! Great plugin.
                            One downside now my layer panel doesn't work anymore with the caption, "update your IE" ?
                            There is definitely something wrong with my settings but no worries, I will try and get both plugins to work.
                            erikB
                            • guanjinG Offline
                              guanjin
                              @renderiza said:
                              I was told this is not WindowsXP Internet Explore, 9 versions, only the Internet Explorer8, you can not use the Internet Explorer8?
                                renderiza
                                @guanjin said:
                                Will soon provide another version that should be working no matter which version of IE is installed. Seems that using css for modifying input fields & buttons is not allowing people with IE 8 or lower to use it...not sure though.
                                Seems Internet Explorer is not going to provide support for Windows XP and Mac operating sistems. Sketch Up might need to adopt another browser like chrome or Firefox in the future. 😕
                                • U Offline
                                  Ulimann
                                  Hallo,
                                  I had problems with IE 10,reinstalled and your wonderful plugin is working.
                                  Thank you.http://sketchucation.com/forums/posting.php?mode=reply&f=323&t=54677#
                                    renderiza
                                    @ulimann said:
                                    Hallo,
                                    Thank you.
                                    I am glad to hear that. 👍
                                      renderiza
                                      [pre:1qax22vv]Authors:: Anar | Dan Rathbun | Pilou | Renderiza | TIG
                                      Version:: 1.0.3
                                      Date:: 11/4/2013
                                      Cost:: Free[/pre:1qax22vv]
                                      FaceSplit v1.0.3 is now available for download.
                                      This version improves the capability of splitting a face with inner loop. This will only work with one inner loop and not more though.
                                      • guanjinG Offline
                                        guanjin
                                        @renderiza said:
                                        [pre:2t5ndb7h]Authors:: Anar | Dan Rathbun | Pilou | Renderiza | TIG
                                        Version:: 1.0.3
                                        Date:: 11/4/2013
                                        Cost:: Free[/pre:2t5ndb7h]
                                        Why not improve it in XP system browser 8 at work, your plug-in I do not work here
                                        • jiminy-billy-bobJ Offline
                                          jiminy-billy-bob
                                          Why support a 12 years old OS and an outdated browser ?
                                          Sometimes it's better and easier for everyone to upgrade and follow technology.
                                            renderiza
                                            Have not yet started to make compatible version but it is on my to do list. 👍
                                            That would be very helpful indeed. 😆
                                            Still though will be nice to support XP user. 😉
                                            • 2 / 3
