    [Plugin] FaceSplit v1.0.3
    44 Posts 18 Posters 34.0k Views 18 Watching
      Seems working fine 😄
        And all medians are present! 👍
        I don't want imagine the possibilities in 3D! 💚
        • renderizaR
          renderiza
          TIG: Thank you TIG will test that out effective immediately! 🎉
          Pilou & Anar: People that bring ideas to the table deserve recognition as well. 👍
          glro: That would be very cool indeed! I think there is a plugin that does something like this but don't remember it just now. If I find it will let you know. 👍
          Pilou: Very cool! 👍
          [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
          • PixeroP
            Pixero
            Hi!
            May I suggest an addition.
            For people working in 3ds Max a imported SketchUp model is sometimes hard to work with because it doesn't consist of evenly sized quad faces. I have this idea to be able to split a face with inner loops like windows by projecting lines in the direction of the edges to the outer loop.
            See this quick sketch.
            • G
              glro
              @renderiza said:
              [b]glro:
              Maybe you think also to voxelize.rb
              http://sketchucation.com/forums/viewtopic.php?t=36063
              but voxelize makes cubes only; it would be funny to split the volume in exact sub-volumes, and try to build the whole volume back again, using sketchup
              i have a 3d connexion mouse, and there is a game like this, to learn how to use it
              and in addition, splitting a volume in sub-volumes is equivalent to building a 3d mesh, for structural analysis...
              • renderizaR
                renderiza
                This is excellent idea! It will produce the cleanest geometry possible before dividing it even more. 👍
                The plugin I had in my mind was not voxelize...it was one that only worked if you had SketchUp Pro.
                Anyways making a plugin like this would be cool indeed. Not sure if I possess the knowledge to do it myself at the moment but will see if I can experiment with the idea in the future.
                • renderizaR
                  renderiza
                  [pre:3p20mm78]Authors:: Anar | Dan Rathbun | Pilou | Renderiza | TIG
                  Plugin Name:: FaceSplit
                  Version:: 1.0.1
                  Date:: 10/28/2013
                  Cost:: Free[/pre:3p20mm78]
                  FaceSplit v1.0.1 is now available for download.
                  http://s18.postimg.org/6mnop92dl/split_dlg.png
                  Note: Will eventually make video explaining how to use plugin.
                    Sure a video will give some ideas to users! 😄
                    What are the natures of the up date ?
                    http://sketchucation.com/forums/download/file.php?id=111403
                    • guanjinG
                      guanjin
                      我点击图标,没有任何反应!
                      • cottyC
                        cotty
                        @guanjin said:
                        我点击图标,没有任何反应!
                        You should click after you have selected one or more faces.
                        my SketchUp gallery
                        • guanjinG
                          guanjin
                          @cotty said:
                          @guanjin said:
                          我点击图标,没有任何反应!
                          I have tried。
                          Thank you
                            thanks for sharing~~~~~~~~
                            • U
                              Ulimann
                              I have tried but no success,to get this plugin to work.I have reinstalled a few times!
                              Running SU 8 Pro on Windows 7.
                              Any suggestion to get it working?
                              • erikBE
                                erikB
                                same here.
                                also SU8 pro and win 7 (64)
                                I also think I have all the administrator rights set on every subdirectory.
                                Strange, I can see the icon but can not click on it nor can I change the number.
                                erikB
                                • renderizaR
                                  renderiza
                                  Uploaded another version to Plugin Store please download it and try to see if it works. The last version used HTML5 to play sound and that might of caused the plugin not to work with people that didn't have latest Internet Explorer version installed.
                                  Download Internet Explorer Here.
                                  If that didn't solved it please let me know...Thanks! 👍
                                  Note: If anyone finds error on 'Ruby Console' please let me know. Here is how to get that information... Open it on 'window>Ruby Console' and then try running Canvas. If Ruby Console detects anything it should show up in window.
                                  • erikBE
                                    erikB
                                    I am a firefox user, but updated IE with link above,... and it works !! Great plugin.
                                    One downside now my layer panel doesn't work anymore with the caption, "update your IE" ?
                                    There is definitely something wrong with my settings but no worries, I will try and get both plugins to work.
                                    erikB
                                    • guanjinG
                                      guanjin
                                      @renderiza said:
                                      I was told this is not WindowsXP Internet Explore, 9 versions, only the Internet Explorer8, you can not use the Internet Explorer8?
                                      • renderizaR
                                        renderiza
                                        @guanjin said:
                                        Will soon provide another version that should be working no matter which version of IE is installed. Seems that using css for modifying input fields & buttons is not allowing people with IE 8 or lower to use it...not sure though.
                                        Seems Internet Explorer is not going to provide support for Windows XP and Mac operating sistems. Sketch Up might need to adopt another browser like chrome or Firefox in the future. 😕
                                        • U
                                          Ulimann
                                          Hallo,
                                          I had problems with IE 10,reinstalled and your wonderful plugin is working.
                                          Thank you.http://sketchucation.com/forums/posting.php?mode=reply&f=323&t=54677#
                                          • renderizaR
                                            renderiza
                                            @ulimann said:
                                            Hallo,
                                            Thank you.
                                            I am glad to hear that. 👍
                                            • 2 / 3
