    Reference and Slave Models
    5 Posts 3 Posters 489 Views 3 Watching
    • SektaS Offline
      Sekta
      Hi All,
      As my models get more complex ๐Ÿ˜ฎ ๐Ÿ˜ฎ with many different views I am looking to adopt Nick Sonders method ๐Ÿ˜Ž ๐Ÿ˜Ž of having a master model with several referenced sub models for internal elevations and joinery and ceiling plans etc.I was looking for suggestions on the best method to achieve this. I cant quite figure how to update the sub-model once the master model has been adjusted. Is the trick to create a component of the entiremodel? Any suggestions would be appreciated. ๐Ÿ‘ ๐Ÿ‘
      • SektaS Offline
        Sekta
        Thanks dave,
        I think I am following you, I will give it a go tomorrow. ๐Ÿ‘ ๐Ÿ‘
          I deleted my post hoping you hadn't seen it. I need to revise some of it but have to get ready for work first.
          • srxS Offline
            srx
            Thanks to TIG, you can do it like in AutoCAD...
            http://sketchucation.com/resources/pluginstore?pln=XrefManager
            www.saurus.rs
            • SektaS Offline
              Sekta
              Yep, XRef Manager works a treat. Thanks ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
