    Dashed Lines Too Large in Print
    Scheduled Pinned Locked Moved LayOut Bug Reporting
    layout
    7 Posts 5 Posters 9.8k Views 5 Watching
      SonataGardener
      I am new to layout, so I am probably missing something.
      But using the same setting for regular and dashed lines, I get huge dashed lines when trying to print.
      Thanks for any input.
        What are the settings for your dashed lines?
          SonataGardener
          Hey Dave,
          Thanks for the quick reply.
          I have the same settings for the continuous line at the top
          • FrederikF Offline
            Frederik
            The image shows a print preview screen dump, but does the actual print also look like that...?
            Personally I never use the print preview option...
            I just did, using the same setting you've posted and I get the exact same print preview, however, if I print it on a paper or to a pdf-file, it looks correct...
            So this must relate to a bug in the print preview part...
            Another comment...
            You've set your stroke to 0.01 pts... 😲 Why...?
            Try with a standard 0.10 pts... Should definitely be enough... 😉
            Cheers
            Kim Frederik
              SonataGardener
              Thanks much! Printed fine. Yes, it must be a preview bug, I will submit it.
              On the 0.01 setting, I was trying to get the stroke size down, obviously no need, all is good.
              Thanks again to both of you for your time.
                marcdurant
                We've had this bug in our tracking system for some time... we've tried some things to fix it but without success (so far). Please do let us know if you find that the actual print appears with the fat lines as well.
                thanks,
                Marc
                • yorik1984Y Offline
                  yorik1984
                  On the 0.01 setting
                  Thickness is not important. The same situation with any thickness.
