    Error Message
    8 Posts 2 Posters 420 Views 2 Watching
    • S
      SushiQ
      When starting Sketcup 8 (free) I keep getting the following message:
      Error Loading File __loader.rb
      uninitialized constant Traductor
      This happened after trying to install the bezierflight plugin
      I have successfully installed the rounded corner plugin, but other plugins don't work somehow. I can't find out why though, they all have .rb . Why would one plugin work and not the other?
      Can anyone help me with this problem? Thnx in advance
      SushiQ
        Make sure you have installed any required supporting files and that you have full Read AND Write permissions set for the Plugins folder.
        • S
          SushiQ
          Thank you for your quick reply.
          Full Read and Write Permissions for Plugins Folder?? Where would I find that, how do I give permission?
          I have installed both files necessary to run this plugin. Rounded Corner works perfectly.
            Open Finder and navigate to the Plugins folder. Right click on it and choose Get Info. toward the bottom of the Info window you'll see the permissions. Edit them all so they show 'Read and Write'.
            • S
              SushiQ
              Still Error message: same as above. But after changing all the settings (I had 2) to read and write the plugins do seem to work. So thank you very much for taking the time to help me.
                Glad the plugin works but you still have something not right. Try looking through the Plugins folder for _loader.rb and see if you can figure out where it is.
                • S
                  SushiQ
                  _loader.rb is in my plugins folder, top of the list.
                    I believe it belongs in the LibFredo6 folder not in Plugins. Try moving it there and see if you still get the error message.
