    [Plugin] TIG-scale2volume
    9 Posts 4 Posters 8.6k Views 4 Watching
      Copyright 2014 (c) TIG
      All Rights Reserved.
      THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
      WARRANTIES,INCLUDING,WITHOUT LIMITATION,THE IMPLIED WARRANTIES OF
      MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      Usage:
      Plugins > TIG-scale2volume
      Context-menu > TIG-scale2volume [with a suitable preselection]
      Action:
      Preselect a Solid Group/Component-Instance Object.
      Activate the Tool.
      Object is scaled to be the Volume entered in the dialog,
      you also specify the Units and the scaling's Anchor-Point
      [Object's Bounds-Center or Insertion-Point].
      You can also specify its 'Mode' - to work on the Original or a Copy.
      Objects are made unique.
      The Scaling is one step undoable.
      The dialog displays the Object's Volume in current Units.
      The last used Units, Anchor-Point & Mode are remembered during that session.
      Version
      1.0 20131005 First issue.
      1.1 20131007 Option added to keep original.
      1.2 20140526 Default volume displayed [cu"/cc] from original, to p=9 d.p.
      Download the latest version from the SketchUcation PluginStore http://sketchucation.com/resources/pluginstore?pln=TIG-scale2volume or AutoInstall it from within SketchUp itself using the 'SketchUcation Plugin Store' tool's dialog... http://sketchucation.com/resources/pluginstore?pln=SketchUcationTools
        Here's an update http://sketchucation.com/forums/viewtopic.php?p=493763#p493763
        Now has the option to Scale the Original or a Copy...
        • songtaoS Offline
          songtao
          hi.TIG...
          The ruby seems to have a problem...
          you can have a try...
            @songtao said:
            hi.TIG...
            What is the problem?
            It works fine for me any many other users...
            Can you explain yourself πŸ˜’
            • olisheaO Offline
              olishea
              Hey TIG. I was just discussing how a uniform scale to volume plugin would be useful and you've already done it!! haha great work! πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
              Would it be easy to edit the code to create a scale2surfacearea plugin?
              Some 3D print materials such as ceramic are charged by surface area not volume you see.
              oli
              • cottyC Offline
                cotty
                Like this, but for multifaces?
                my SketchUp gallery
                • olisheaO Offline
                  olishea
                  Yes. For a whole grouped solid. πŸ˜„
                  oli
                    Here's an undated version http://sketchucation.com/pluginstore?pln=TIG-scale2volume
                    There's also a new scale2surfacearea here... http://sketchucation.com/forums/viewtopic.php?p=526694#p526694
                    • olisheaO Offline
                      olishea
                      Thanks for the reply, your plugins are amazing and some of my most frequently used! I must donate when I've got all this work out the way.
                      You're a total star TIG! πŸ‘ πŸ˜„
                      oli
