    Living room interior
    11 Posts 7 Posters 984 Views 7 Watching
    • ginchiusG Offline
      ginchius
      Living room interior. Modeled with Sketchup, rendered with Thea studio, BSD, time 3 hrs 20 min.
      C&C are welcome.
      Thea BSD 3hrs20min
      You can find my models at http://sketchucation.com/shop/models
      • Rafferty94R Offline
        Rafferty94
        Looks good. The two pictures on the far wall look to bright, as in no shadow anywhere around them etc.
        All in all tho, a very nice model!
          jpalm32
          Nice. Are those ceiling lights really that large?
          • BoxB Offline
            Excellent, almost too realistic.
            You need a fault somewhere, a cushion out of place or one of the sections of the blinds twisted slightly so the gap is irregular....
            • Bryan KB Offline
              Very nice!
              • ginchiusG Offline
                ginchius
                Thanks for comments.
                @rafferty94 said:
                ...The two pictures on the far wall look to bright, as in no shadow anywhere around them etc...
                I didn't notice that there is no shadows around the pictures ๐Ÿ˜ฎ and, yes, frames are too bright.
                @box said:
                ...You need a fault somewhere, a cushion out of place or one of the sections of the blinds twisted slightly so the gap is irregular....
                Thanks for the advice. ๐Ÿ˜„
                Yes, these lamps are really large about 580mm diameter.
                • xonptX Offline
                  xonpt
                  you should separate the paintings from the wall, like half a centimeter, so that they dont look like glued to the wall, but hung on
                  apart from that, its almost perfect
                  very good one
                  • ginchiusG Offline
                    ginchius
                    very good one
                    Thanks,
                    I did a 5 mm space between picture and wall, but, I think, there was no shadows around the frames because of bad lighting.
                    • xonptX Offline
                      xonpt
                      very good one
                      Thanks,
                      well, then i shouldnt have said anything, because you actually did what i said... my bad, sorry... lol
                      but its weird how that spacing didnt cast any shadows
                      even so, the images are great!
                      • mortenstorgaardM Offline
                        mortenstorgaard
                        Wow looks really cool. How much of the room was there when you started out (if any). Some solid work!
                        Morten
                        //nordiskspil boardgames
                        • ginchiusG Offline
                          ginchius
                          Later I'll try to rerender this interior to fix mistakes.
                          Thanks for comment,
                          Just one room was when I started ๐Ÿ˜„
