    Offset top face only...need help!
    4 Posts 3 Posters 466 Views 3 Watching
    • renderizaR Offline
      renderiza
      Hi, bellow is an attempt to offset the top face lines but I am running into some issues.
      model = Sketchup.active_model
      ents = model.active_entities
      faces = ents.grep(Sketchup;;Face)
      sel = model.selection
      faces.each do |face|
        if face.normal.z == 1
          edges = face.edges
          edges.to_a.each do |e|
            p1 = e.start.position
            p2 = e.end.position
            x1 = p1.x
            x2 = p2.x
            y1 = p1.y
            y2 = p2.y
            length =  Math.sqrt((x1-x2)*(x1-x2)+(y1-y2)*(y1-y2))
            offset = 10.0
            x1p = x1 + offset * (y2-y1)/length #/
            x2p = x2 + offset * (y2-y1)/length #/
            y1p = y1 + offset * (x1-x2)/length #/
            y2p = y2 + offset * (x1-x2)/length #/
            newedges = ents.add_line([x1p,y1p,p1.z+5],[x2p,y2p,p2.z+5])
            sel.add newedges
      Where do I start ๐Ÿ˜• ...
      Notice that when I add the line, the z coordinates have +5 added because if I make it same height as face the new edges break the next edge that it will offset and mess the result.
      You can see what I mean if you replace "p1.z+5" to "p1.z" & "p2.z+5" to "p2.z". You need to have a face that where z axis = 1.
      What I had in mind was to elevate the edges by 5 and somehow abstract the vertex position where the new edges intersect. Problem is they don't produce any vertex.
      Not sure if I am explaining myself but all I want is to offset the top face. Any help will be appreciated as always.
      Thanks!
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        Read my SmartOffset code to see how I offset the edges of a given face...
        • tt_suT Offline
          tt_su
          Side note - Ruby is very slow. You'll find using the SketchUp API's .distance method much faster than doing your own length calculation. At least if you do this for a somewhat large set of entities.
            renderiza
            ๐Ÿ‘Š ๐Ÿ˜ฎ ๐Ÿ˜ฒ ๐Ÿ˜• ๐Ÿ˜ž ๐Ÿ˜ข
            That is by no means an easy task but I will try to understand what you wrote. Isn't there a 1st grader version? ๐Ÿ˜†
            That is good to know thanks!
