Quickly Renaming Materials
If you want to have use functional names for your materials - such as "Counter Tops" so that they can be easily used for cut lists, for example, then it is handy to rename them as you place them.
The Render Plus Material Placement Wizard make it it easy to view all the materials in your model
Just Right click on any material name to quickly rename it.
Register LoginAdvertisement
