    Sketchup 2013 + windowizer + make faces
    6 Posts 3 Posters 3.0k Views 3 Watching
      subcontent
      I've finally got my big boy pants and have moved from SU 7 to SU 2013
      BACKGROUND
      There are 2 Scripts that I've found to be extremely useful:
      WINDOWIZER (assuming that I need to pay out $10.00 -- which is a bargain)
      MAKE FACES
      QUESTION
      Will these work with SU 2013? I'd like to know before I try to load them up in vain...
      thanks,
      sub.
      😳 ps sorry for the dbl post -- my browser wigged out and thought the post was deleted...
      **%(#FF0000)[------------------
      SOLUTION: Just load them into the Plugins folder -- they work!
        If you already have them, copy them from a SU7 Plugins folder to the Plugins folder in SU2013 and see what happens.
          subcontent
          ... The only problem with that scenario is that I had them for SU6 on my computer. The new place that I'm employed at used 7 -- and they've been doing everything plug-in free as far at they know.
          So, if I bring them in from SU 6 will they work? I guess I can try and see...
          Thanks Dave!
          sub.
            Well, the plugin authors can't do anything about your employer but if you've got copies of these plugins already on a computer, what have you got to lose. As far as I can tell neither of these plugins saw any updates for use with SU2013. Some plugins did require updates, though.
            • cottyC Offline
              cotty
              If "make faces" don't work, you can try TIGs add faces, it is comparable and works with SU2013.
              my SketchUp gallery
                subcontent
                DAVE: Thanks. I'm almost up to speed! These work fine with SU 2013. Originally I was just trying to get feedback on if they worked rather than do it myself in case I messed anything up. However, I just did like you suggested and I have what I want...in the way of these function.
                COTTY: Thanks for the suggestion!
