    Layer selection
    10 Posts 6 Posters 879 Views 6 Watching
    • fouronethirtyF Offline
      fouronethirty
      greetings sketchucation,
            im having a hardtime hiding groups or components on a layer manager, i was hoping that it can highlight automatically on the layer manager tab, simultaneously as you click on to an specific groups or components,i was wishing it could highlight on the layer  tab so you can uncheck its layer visibility faster,is ther a way we can do that sir, anyone sir
        dedmin
        Here we go - http://sketchucation.com/forums/viewtopic.php?t=20949
        • cottyC Offline
          cotty
          One way without plugins:
          • select object
          • see layer in Entity Info window
          • search layer
          my SketchUp gallery
            fouronethirty
            • select object
            • search layer
            yes sir, thank you very much, but i was hoping it could go to its layer name by the time you select the object, without looking into its entity info name, i think it would be a faster selection to hide layer visibility
              fouronethirty
              layer names of components and groups should be highlighted automatically at layers tab by the time we select it to facilitate easier and faster layer hiding, checking and unchecking or showing its visibility .. it only worked in outliner tab but it does'nt in layer tab.. please advice ladies and gentleman, thank you, ,
                You can already get that with the Layers toolbar. I find Entity Info works just fine for that since I always have it open where I can see it.
                • arail1A Offline
                  arail1
                  I wish the Entity and Layers panel were one or could be made into one optionally.
                  • BoxB Offline
                    They do clip together.
                      fouronethirty
                      Subject: Layout 2014 Wishes
                               Hi, Greetings Sketchucation, . As layout had a very excellent  improvements on drawing documents managing for the users, it was indeed a better and greater tools for us, as an aspiring architect. . and so i would want it to have again an enhancement , again and again.:smile: 1 thing i noticed is the.
                      1. Selection inside groups to edit while you zoom in using the zoom drag zooming,which is faster and its "great" than the mouse wheel zooming, it instantly exit the selection when u select and use zooming simultaneously, this does not hapen inside sketchup, how come it does in layout, , its a helpfull and efficient command so i would want layout to have it too.
                      2. Layers name right click selection, and layers, lines, styles entity in right click selection manner,
                        I wish layout could have that, thank you sketchucation,
                        fouronethirty
                        goodmorning sketchucation,
                        Thanks a lot for the guides. i appreciate it a lot, thank you,
