    Skp 2013 to Dwg problem
    3 Posts 3 Posters 365 Views 3 Watching
    • jhonpaybollJ Offline
      jhonpayboll
      Hi, this is my first time posting here, not sure if its the right place, but hopefully i can get some advice...
      I just changed to sketchup 2013 and now I'm having a hard time whenever I do a 2D graphic export. The problem is if I export a view from Sketchup 2013 to Autocad, some lines just disappear. I'm not sure if it's a known bug, but when I google it I don't find anything around.
      If I do a section cut export, the lines export just fine, but the problem is when I do the 2D Graphic export. Right now I'm doing both, and then paste the section cut over the 2d Graph, and that works, but with Sketchup 8, just doing the 2D export was enough.
      Anyone having the same issue?
      Thanks!
        Please complete your profile with operating system and SU version. That'll help you get help.
          chadgould
          First place I would check would be your export options dialog box to make sure the settings are similar in 13 to what you had been using in 8. If this doesn't fix the export, then you might check to see if the lines are really not there as sometimes their color properties in autocad match the color of your screen background and it looks like the drawing is empty. Try opening your empty drawing in autocad and doing a select all. you will quickly see in the dialog box how many entities it has found. next type in properties from the command prompt and change the color properties to a different color and see if that lights them up.
          best wishes,
          Chad
