    Frozen scene manager
    4 Posts 3 Posters 438 Views 3 Watching
    • emerald15E Offline
      emerald15
      Could anyone help, please!
      I'm working on a drawing & have set up one initial scene. When I came to set up a second scene the file has frozen with this message regarding thumbnails(which I don't use anyway). Between setting each scene I have been adjusting a couple of components (ceiling panels - setting them not to cast shadows) & adjusting some of the settings for the chosen style but nothing else. I've run 'cleanup' & found nothing wrong.
      I will attach the file if required.
      ... it appears not to be file related but is triggered if I right click on the scene tab & select 'scene manager' (see attached) - there after, every new scene brings up the thumbnail message & is frozen.
        amo
        I have had the same issue with the Scene Manager freezing on me. I was able to get rid of it but I had to open a new file and paste in place each of my 3 groups into the new file. After this I was able to add more than 1 scene without it freezing on me.
        I have also run into an issue with saving the same file. I get a handful worth of saving to the same name before I need to change the name. If I don't it freezes and takes about 5hrs to save.
        Hope this will work for you.
          jpalm32
          Hope this will work for you.[/quote]
          Thank you. I have save & rename problem also.
          Comes out of nowhere. Size of scene doesn't matter either.
          Someone suggested it might be permissios and it's not.
            emerald15
            Yes, I've been trying that myself. Further investigation has shown that is I set the scene manager to 'detail' (previously it was set to 'list') this seems to work. However, the files already effected by the problem will not re-open (the position they were last saved at being a view with complex shadows).
            At present we think it could be a clash with other software. I am continuing with the project re-building from a previous model (I'll lose about 5 hours work) with these new settings & save, save, save!
            In the mean time, if anyone has any other suggestions...
