    [Plugin] Multiple Component Edit Warning
    77 Posts 21 Posters 46.1k Views 21 Watching
    • ashscottA Offline
      ashscott
      This is a plugin I shared the idea for some time ago here: http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=50800
      I didn't have the coding skills to make it happen but I really felt that, to use sketchup's component system to its full potential, without being afraid of editing stuff accidentally, this plugin was a must have.
      So I forked out some cash and got Dan Rathburn to code it up (I think he did a great job by the way). It gives you a webdialog notification whenever more than one component is being edited and tells you exactly how many components are being edited.
      You can ignore the webdialog and go on editing the components or you might realize that you don't want to edit all those components at once and, as a result, make some unique and begin editing again - in only a few weeks of use it has saved me a lot of headaches and sped up my workflow greatly as I'm now not afraid to use components to their full potential.
      There's no reason why I should get all the benefit so here it is for you to enjoy.
      Updated version 2.4.0
      PM me if you find any issues...
      The latest edition should be available from the PluginStore http://sketchucation.com/pluginstore?pln=CoastalConcepts_EditFlag
      CoastalConcepts_EditFlag_v2.4.0.rbz
      Just some stuff I do with Sketchup.
      • jolranJ Offline
        jolran
        πŸ‘ for actually paying someone doing a job.
        • ashscottA Offline
          ashscott
          Hey, you gotta pay for good work
          E 1 Reply Last reply Reply Quote 0
          • gullfoG Offline
            gullfo
            thanks! great idea - i also hate it when i spend 15 minutes tweaking something only to find i forgot to make it unique before starting. so this will be a big help!
            Glenn
            http://www.runnel.com
            • ashscottA Offline
              ashscott
              Glad you like it
              • KrisidiousK Offline
                Krisidious
                You mean now I can stop copy, undo, undo, undo, undo, undo, undo, undo, undo, undo, undo, undo, undo, paste in place...? awesome possum!
                By: Kristoff Rand
                • ashscottA Offline
                  ashscott
                  Not sure what workflow you've been using but it sounds like this plugin is just what you need...
                    Krisidious
                    Those are commands I use when I've accidentally edited a component. It allows me to keep the changes to the component I've just made and then go back to a point when the other components are not edited. Then "Paste in Place" remembers what you copied, the "new" component. But this should keep me from having to ever use that workflow... Thanks. and Thanks to Dan.
                    By: Kristoff Rand
                    • ashscottA Offline
                      ashscott
                      I see what you mean - my workaround was check the last autosave time and hope I saved it not too far before I began editing the components - that workaround failed me many times
                        Krisidious
                        My method works everytime... I think it goes back until the last save. however far back "undo" goes.
                        By: Kristoff Rand
                        • JQLJ Offline
                          JQL
                          I just bumped into this thread and I must say, this is an excellent plugin!
                          Thank you for sharing,
                          JQL
                          www.casca.pt
                          Visit us on facebook!
                          • ashscottA Offline
                            ashscott
                            Glad you like it πŸ˜„
                            • JClementsJ Offline
                              JClements
                              Thanks Ash and Dan. I wish I had this a long time ago. Great idea!
                              I modified the dialog caption of my EditFlag_en-US.rb file so that I can remember the source ruby filename.
                              • ashscottA Offline
                                ashscott
                                In case you want to move it or make changes later?
                                • JQLJ Offline
                                  JQL
                                  Hi again,
                                  When working on nested components, there are two things happening that I think could be revised.
                                  1 - The flag doesn't go off as I dig inside components nested inside other components. One has to turn them off manually.
                                  2 - The value showed does not reflect how many components really exist in the model if there are components inside other components.
                                  Still better to have it than not so thanks again,
                                  JQL
                                  Either
                                  www.casca.pt
                                  • ashscottA Offline
                                    ashscott
                                    Yes, could certainly do a little more development - this will be taken into account for the next revision
                                    • JQLJ Offline
                                      JQL
                                      Ashscott,
                                      If you are further developing the plugin, I got an idea from using it that I think you could consider, even if it's not that important and there are many ways to get around it:
                                      The window could go a step further and besides displaying the message, it could have a one click button for extending zoom to all similar components, and back to where you were editing.
                                      It's just a minor thing but the alarm box would become both text and function, and all aspects related to the anxiety of editing components would be covered.
                                      Again, this is a very nice plugin, and should have been there from the start. Best regards and thank you.
                                      JQL
                                      www.casca.pt
                                        Sir
                                        Your idea is fantastic!
                                        but it doesnt work with V7 😒
                                        I was so excited to use it as well. πŸ’š
                                        • ashscottA Offline
                                          ashscott
                                          Are you sure it doesn't work with V7? It has been tested for V7 so it should work....
                                          • ashscottA Offline
                                            ashscott
                                            Any Response to V7 query?
                                            I love your ideas JQL - I will have to save a little cash to implement them as I'm paying for development out of my own pocket.
                                            • 1 / 4
