    [Plugin] Multiple Component Edit Warning
    77 Posts 21 Posters 50.6k Views 21 Watching
    • ashscottA
      ashscott
      Hey, you gotta pay for good work
      Just some stuff I do with Sketchup.
      E 1 Reply Last reply
      • gullfoG
        gullfo
        thanks! great idea - i also hate it when i spend 15 minutes tweaking something only to find i forgot to make it unique before starting. so this will be a big help!
        Glenn
        http://www.runnel.com
        • ashscottA
          ashscott
          Glad you like it
          • KrisidiousK
            Krisidious
            You mean now I can stop copy, undo, undo, undo, undo, undo, undo, undo, undo, undo, undo, undo, undo, paste in place...? awesome possum!
            By: Kristoff Rand
            • ashscottA
              ashscott
              Not sure what workflow you've been using but it sounds like this plugin is just what you need...
              • KrisidiousK
                Krisidious
                Those are commands I use when I've accidentally edited a component. It allows me to keep the changes to the component I've just made and then go back to a point when the other components are not edited. Then "Paste in Place" remembers what you copied, the "new" component. But this should keep me from having to ever use that workflow... Thanks. and Thanks to Dan.
                By: Kristoff Rand
                • ashscottA
                  ashscott
                  I see what you mean - my workaround was check the last autosave time and hope I saved it not too far before I began editing the components - that workaround failed me many times
                  • KrisidiousK
                    Krisidious
                    My method works everytime... I think it goes back until the last save. however far back "undo" goes.
                    By: Kristoff Rand
                    • JQLJ
                      JQL
                      I just bumped into this thread and I must say, this is an excellent plugin!
                      Thank you for sharing,
                      JQL
                      www.casca.pt
                      Visit us on facebook!
                      • ashscottA
                        ashscott
                        Glad you like it πŸ˜„
                        • JClementsJ
                          JClements
                          Thanks Ash and Dan. I wish I had this a long time ago. Great idea!
                          I modified the dialog caption of my EditFlag_en-US.rb file so that I can remember the source ruby filename.
                          • ashscottA
                            ashscott
                            In case you want to move it or make changes later?
                            • JQLJ
                              JQL
                              Hi again,
                              When working on nested components, there are two things happening that I think could be revised.
                              1 - The flag doesn't go off as I dig inside components nested inside other components. One has to turn them off manually.
                              2 - The value showed does not reflect how many components really exist in the model if there are components inside other components.
                              Still better to have it than not so thanks again,
                              JQL
                              Either
                              www.casca.pt
                              • ashscottA
                                ashscott
                                Yes, could certainly do a little more development - this will be taken into account for the next revision
                                • JQLJ
                                  JQL
                                  Ashscott,
                                  If you are further developing the plugin, I got an idea from using it that I think you could consider, even if it's not that important and there are many ways to get around it:
                                  The window could go a step further and besides displaying the message, it could have a one click button for extending zoom to all similar components, and back to where you were editing.
                                  It's just a minor thing but the alarm box would become both text and function, and all aspects related to the anxiety of editing components would be covered.
                                  Again, this is a very nice plugin, and should have been there from the start. Best regards and thank you.
                                  JQL
                                  www.casca.pt
                                    Sir
                                    Your idea is fantastic!
                                    but it doesnt work with V7 😒
                                    I was so excited to use it as well. πŸ’š
                                    • ashscottA
                                      ashscott
                                      Are you sure it doesn't work with V7? It has been tested for V7 so it should work....
                                      • ashscottA
                                        ashscott
                                        Any Response to V7 query?
                                        I love your ideas JQL - I will have to save a little cash to implement them as I'm paying for development out of my own pocket.
                                        • JQLJ
                                          JQL
                                          Ashscott,
                                          I thought you were co-developing the plugin. It's very generous of you to pay for development and then sharing it with all of us. Most of the people here share they're own work and passion and accept donations if people willingly give them. To pay for sharing is something admirable. Specialy now, that many of us struggle with difficult financial questions.
                                          Best regards,
                                          JQL
                                          www.casca.pt
                                          • ashscottA
                                            ashscott
                                            Its improved my productivity - why not share it and let others gain the same?
                                            • 1 / 4
