    "Enter" key is not working in SU WebDialogs. Bug?
    4 Posts 3 Posters 469 Views 3 Watching
    • fuzzybroF Offline
      fuzzybro
      Hello,
      I've encountered a problem while making a GUI for a SketchUp plugin. I need to get an input confirmation from the user by pressing "Enter key", but I have found out that no KeyDown event is firing in SketchUp WebDialogs, but it is firing in a regular browser (IE/Chrome/Firefox)
      the simple code if here:
      <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
      <html xmlns="http://www.w3.org/1999/xhtml" lang="en" xml;lang="en">
        <head>
          <meta http-equiv="content-type" content="text/html; charset=utf-8" />
          <!--<meta http-equiv="X-UA-Compatible" content="EmulateIE8"> -->
          <title>Test Window</title>
          <script type="text/javascript">
            document.onkeypress = function (e) {
              e = e || window.event;
              var charCode = e.charCode || e.keyCode;
              if(charCode == 13) {
                alert("key pressed");
          </script>
        </head>
        <body>
        </body>
      </html>
      Is it a common thing or I'm the only one who is getting the restriction?
      I've checked this behaviour in SketchUp 8 and 2013 on Win7 and Win8 and have got consistent results.
      How WebDialog web browser is different from regular IE on the system?
      OctaneRender for SketchUp Overview and Demo Version
      Latest updates, tutorials and artwork
      facebook.com/octane4sketchup
        No 'key-presses' get processed BUT using document.onkeydown instead will work - so change it.
        To see what's happening temporarily replace
        if(charCode == 13) { alert("key pressed"); }
        with just
        alert(charCode);
        You'll see the number of each key-down you do - '13' is Enter...
        • tt_suT Offline
          tt_su
          I always recommend that people use a JS framework to take care of the compatibility issues - leaving you to interact with a unified API. My personal preference is jQuery.
          I used that in SKUI where I capture ESC and Enter: https://github.com/thomthom/SKUI/blob/master/src/SKUI/js/ui.window.js#L21
          • fuzzybroF Offline
            fuzzybro
            Ah, so simple 😳
            Thank you guys!
