    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 316.4k Views 110 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      @leolouie2 said:
      I have just downloaded this for the 1st time. Is there a way to make it recognized existing layers in the model?
      It should do that by default.
      Are you using Windows ?
        jiminy-billy-bob
        New version 0.5 beta !
        Changelog :
        • Displays a warning when drawing geometry to another layer than layer0
        • New Delete button that moves content to the current layer
        • New button to set selection's layer as current layer
        • New button to move selection to highlighted layer
        • Now supports Podium render
        • Option to purge unused groups
        • Option to hide the render toolbar
        • Option to open Layers Panel when Sketchup starts
        • Potential fix for rename bug
        http://i.imgur.com/KJOyOXA.png
        Download in the plugin store !
        • cmeedC Offline
          cmeed
          Hello Again - potential bug....
          I opened my work from last night this morning - a popup saying the new version was out - downloaded
          • closed layer panel (as nothing had changed) -
            -opened Layer panel again - could see there were new features - tried options, from the new pull down - nothing happened
          • tried new 'move selection to highlighted area' didn't seem to work
            -closed Su
            _open SU
          • opened layer Panel
            -All groups gone 😞
            Layers still present
          But
          'Options' and 'move selection to highlighted layer' now work as expected. and I'm supposing the rest works too
          (also when turning off render toolbar there's a big gap at the top.... suggest this render feature goes at the bottom no need to give such high status, you're going to use it for a short period while layers all the time....just a thought)
          No Big issue for me on this project as I've finished but you better see if anyone else has had a problem
          Keep up the great work - Fantastic plugin has changed my work flow tremendously
          -just thought about your 'move to selected layer' how about 'move and rename' mmmmm interesting - you might be stepping on 'rename by layer plugin' toes but maybe you could get together - they work as a great accompaniment
          c
          • cmeedC Offline
            cmeed
            updating a scene using a shortcut (in my case 'p')with Layer Panel Open now works - great stuff
            Cheers
            c
              jiminy-billy-bob
              @cmeed said:
              -All groups gone 😞
              This is a real problem πŸ˜• I'll need to add a debug mode so that users can check if groups are gone for good, or if there is just a bug displaying them. Could you send me the file ? (Even without geometry)
              I was able to reproduce that, it seems to be a CSS problem, I'll release a fix soon.
              Nope, Renderiza's plugin works great, no need to replicate the work πŸ˜„
                jiminy-billy-bob
                Cheers
                c
                Great ! Don't know what was causing that, but I'm glad you don't have the issue anymore.
                  jiminy-billy-bob
                  Also, I see that the menu button is invisible on IE9, I'll try to fix it.
                  • cmeedC Offline
                    cmeed
                    Nope, Renderiza's plugin works great, no need to replicate the work πŸ˜„[/quote]
                    all I'm saying is, ergonomically it would be better.... Thats all πŸ˜‰
                      jiminy-billy-bob
                      Can anyone confirm this ?
                        jiminy-billy-bob
                        New version 0.5.1 beta !
                        Changelog :
                        • Fix gap at the top when hiding the render toolbar
                        • plesiosaurP Offline
                          plesiosaur
                          Any plans to add Thea to the Render list? Thanks
                            jiminy-billy-bob
                            @cmeed said:
                            -All groups gone 😞
                            The groups unique IDs are still present in your file, but they are not listed by Layers Panel serialized string. Don't know why...
                            Were layers still sorted, or did they revert back to Sketchup's default sorting ?
                            Did anyone else experienced this ?
                              jiminy-billy-bob
                              See this :
                              Actually, if it works with Thea on day, it'll behave differently. You will probably have an option directly inside Thea allowing you to choose if you want to render with Layers Panel feature or not. But you won't render from within Layers Panel as you do with Vray/Maxwell/etc. This is due to the way Thea is designed. I can't trigger the render from my plugin.
                              I gave evrything to Tomasz to make it work, the ball is on his side now πŸ˜‰ So if you badly want this feature, you should get in touch with him !
                              πŸ˜„
                              • cmeedC Offline
                                cmeed
                                @cmeed said:
                                -All groups gone 😞
                                The layers were not in any order.
                                  jiminy-billy-bob
                                  Maybe the order they were created ? (Which is SU's default)
                                  • ElibjrE Offline
                                    Elibjr
                                    Any thought to adding Render[in], IRender-nXt or Shaderlight to the list? This is such a great plugin! Thank you for all your work.
                                      jiminy-billy-bob
                                      Same case as Thea, I have to contact the developers.
                                      • Bob JamesB Offline
                                        Bob James
                                        Any progress with regard to solving the problem with the interference with the saving of scenes?
                                          jiminy-billy-bob
                                          Working on it πŸ˜‰
                                            jiminy-billy-bob
                                            Bug found : When a group is moved to be nested in another group, we can't rename it. We have to restart Layers Panel.
                                            Working on a fix.
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 33
                                            • 34
                                            • 9 / 34
