    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 309.3k Views 110 Watching
    • G Offline
      glro
      @jiminy-billy-bob said:
      @glro said:
      sketchup just freezed when i clicked on "select highlighted layer"
      Any more detail which could help me identify the issue?
      nothing much to say
      i had created some scenes previously, and then i launched layers panel plugin to select one layer, and it freezed the computer
      i shall give it another try, and try to atch better the next time i have a bug
      • JQLJ Offline
        JQL
        Hi Jiminy,
        I have another feature request for your layers panel.
        Delete layer's content while keeping layer.
        It's handy in a lot of situations, for me, for instance it's nice so I can delete the content on layers on my template file. It's also good to clean a "trash" layer I have sometimes, where I put a lot of stuff on that trash layer so I can fall back to it later on... I can imagine a lot of useful scenarios like deleting certain layers to share a file by email.
        I hope you'll be able to do it and thanks once again,
        João
        www.casca.pt
        Visit us on facebook!
        • jiminy-billy-bobJ Offline
          jiminy-billy-bob
          I'll add it to my todo list.
          • JQLJ Offline
            JQL
            Thanks Jiminy, that's great!
            www.casca.pt
            • F Offline
              fountainhead
              Sorry for the late reply, was away for holidays.
              OS is Windows 8.1 update 1
              IE version is 11.0.9600.17239
              SketchUp 2014 14.1.1282
              The add layer functionality does not work when the dialogue opens blank.
              Empty plugins folder, layers panel only, works. So time to start process of elimination, or do you have some well known offenders I could start the weeding out process with?
                jiminy-billy-bob
                I have no idea, but you could send me your whole Plugins folder, and I'll investigate when I have time. (In at least two weeks)
                • danchoD Offline
                  dancho
                  Hi jiminy-billy-bob,
                  I like your plugin but I found some strange thing.
                  There is a differende between content of builn in layer window
                  and your plugin. In the built in there is sometimes more layer
                  than in yours.
                  OS_win7 home prem. x64
                  IE_11.0.9600.17239
                  SU_2014 latest
                  BR.
                  Daniel
                  difference
                  • F Offline
                    fountainhead
                    The offending plugin is eneroth 3D rotate. With associated . rb file removed, no layer loading issues.
                    • G Offline
                      glro
                      i have strange behaviours with Layers panel, and i use eneroth 3D rotate too...
                      any suggestion to modify one or both plugins to make them work together?
                        jiminy-billy-bob
                        New version 1.2.1 !
                        Changelog :
                        • Fixed a major issue that could corrupt the model (Caused by SU14 and below)
                        • Fixed States dialog
                        • Added API methods
                        Download in the plugin store !
                        • G Offline
                          glro
                          New version 1.2.1 !
                          Changelog :
                          • Added API methods
                          thank you
                          i give it a try to check if it solves the issues i had
                          when i launch the plugin for the first time in a model made before the installation, an almost empty layers panel window opens, with only one layer, and i get a message "layers panel needs to be fixed"; i click "OK"
                          An html windows pops up, saying no issues are detected...
                          I close the pop up window and the empty layers panel window
                          The next time i open the layers panel window, all layers are shown
                          close the model, open it again ...
                          everything seems to be working fine...
                          no issues detected
                            jiminy-billy-bob
                            This is normal behaviour. It is triggered by the fact that there are existing layers that need to be identified by LP. This is a one-time thing, and won't trigger again (unless there are layers created while LP is disabled).
                            Maybe I should change it to say that issues have been fixed, not only that there are no issues. It may be misleading as is.
                            Do you guys still have issues with Eneroth's Rotate3D? I can't reproduce your errors.
                            • G Offline
                              glro
                              yes, maybe the message is not totaly accurate ; there is no problem;it is just that the existing layers must be registered by layers panel plugin
                              somebody suggested that there was a conflict between Eneroth's Rotate 3D and your plugin, but gave no evidence; so i don't know about it; i shall be using layers panel in the coming daus, and i also run Rotate 3D code, so if i notice something wrong, i shall report it
                              • G Offline
                                glro
                                I have been using your "layers panel.rb" for 2 or 3 days, it worked fine
                                but today, it proved to be not compatible with a plugin containing rotate3D code
                                i am not skilled enough to say why, but it seems to confirm there is a problem...
                                too bad, it improves a lot the sketchup native layers panel
                                  jiminy-billy-bob
                                  Did you get an error message?
                                  What happened exactly?
                                  • G Offline
                                    glro
                                    sketchup stopped suddenly, and that was it
                                    bugsplat
                                    i tried to remove some newly installed extensions, and this way i found out that "Layers panel" was involved
                                    I can't write more since i don't understand what's happening; your plugin might be perfect; i just know that if i remove it, i don't have the problem
                                    • tt_suT Offline
                                      tt_su
                                      Did you submit that BugSplat? Did you enter any info in the Description or Name field we can use to look it up by?
                                      • G Offline
                                        glro
                                        No
                                        but if you think it might help, i shall
                                        • tt_suT Offline
                                          tt_su
                                          We might be able to get some clues to what cause the crash.
                                          Please always submit BugSplats - even if you do not fill in any info. It helps our statistic when we look for highest source of crashes. But it do helps if you enter some info the first time you experience a crash, and some contact info so we can reach out if we need more info. Then if you experience the crash again just keep submitting, but then there is less need for you to fill out details.
                                            Layer One
                                            I love it, great plugin.
                                            Is there any way to sort the layers, perhaps alphabetically.
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 31 / 34
