    Hide selected objects from scenes except the active one?
    3 Posts 2 Posters 361 Views 2 Watching
    • renderizaR Offline
      renderiza
      I want to hide selected object from all scene except the one that is active.
      This is the code I have so far...any ideas are welcome!
      model = Sketchup.active_model
      pages = model.pages
      sel = model.selection
      pages.each {|page|
      	sel.each do |e|
      		e.hidden = true
      	page.update
      Cheers!
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        Perhaps something like
        pages.each {|page|
          next if page == pages.selected_page # to skip active scene
          renderiza
          Thanks TIG but there is a problem...
          Lets say I have two scenes with two objects and I select the 1st object from 1st scene and do the script...it will work but...if I go to 2nd scene and select the 2nd object to do the script when I go to 1st scene the 1st object ends up hidden as well which it was not supposed to. (Hope this makes sense)
          Anyhow it may be that the page.update needs to first select each page before doing update. So that means I can't use your suggestion but I did find a solution... Here is the code...
          pages = model.pages
          c_page = pages.selected_page
          skip = []
          skip << c_page.name
          pages.each {|page|
              pages.selected_page = page
              if page.name != skip.first
                  sel.each do |e|
                      e.hidden = true
                  page.update
          page_num = 0
          pages.each {|page|
               if page.name == skip.first
                   pages.selected_page = model.pages[page_num]
                   break
               page_num+=1
          skip.clear
          Note: Updated the explanation a bit to fix it a little so it makes more scene hopefully. πŸ˜•
