Bend Stairs to Curved Wall
@ryangarnett said:
Thank you spreadcore...that tutorial was perfect. I didn't know that you had to have the stairs the same height, and that the straight line needed to be the same length as the rise. These were then things I was missing.
Thanks again....really helped!
Your welcome, glad it worked for you.
FYI:
The straight line needs to be the same length as the "Run" of the stairs.The "Rise" is the height of the stairs.
Thanks again...
Register LoginAdvertisement
