    Bend Stairs to Curved Wall
    22 Posts 6 Posters 2.3k Views 6 Watching
      ryangarnett
      Here is a sample of the tankers I need to model. So the "building" or tank with height will be provided, but I have to add the detail (stairs). And as you can see in the picture, the stairs "snap" to the side of the tank and do not overlap.
        ryangarnett
        I'm not trotting out new detail, its in the post "to curved wall". You are proposing changing my wall, so I am providing you the information as to why that won't work.
          [screenr:2fyym52b]fwXH[/screenr:2fyym52b]
          • jeff hammondJ Offline
            @rich o brien said:
            fwXH
            πŸ˜†
            i found fault with that.
            (j/k)
              spreadcore
              Just asking is this close to what your trying to do?
              I used shape bender.
              http://s5.postimg.org/hr2p2wvyf/fueltank.jpg
                ryangarnett
                Yes that is exactly what I am hoping to achieve. When I have used Shape Bender it lines the stairs up wrong. Would you mind sharing your steps, etc...
                Thanks...
                  spreadcore
                  Thanks...
                  I assume your referring to me.
                  Okay I made a tutorial, I hope I did it right first time making one.
                  FYI: I used TIGs ArcBy plugin to make the arc.
                  TIGs ArcBy Plugin here...
                  http://sketchucation.com/resources/pluginstore?pln=TIG_arcBYtools
                  TIGs ArcBy...
                  I used the "Radius+Length"
                  • Type in radius of the cylinder
                  • Type in length of the arc
                  • Change number of segments
                  tank_stairs_tut.skp
                    ryangarnett
                    Thanks Spreadcore...I will try that for sure....Thanks again...
                      ryangarnett
                      Thank you spreadcore...that tutorial was perfect. I didn't know that you had to have the stairs the same height, and that the straight line needed to be the same length as the rise. These were then things I was missing.
                      Thanks again....really helped!
                        spreadcore
                        Your welcome, glad it worked for you.
                        FYI:
                        The straight line needs to be the same length as the "Run" of the stairs.
                        The "Rise" is the height of the stairs.
                          ryangarnett
                          Thanks again...
                          • 2 / 2
