    Image texture resolution limitation
    renderpluginsextensions
    3 Posts 2 Posters 862 Views 2 Watching
      amorp
      Hello everyone,
      I use Sketchup 8+Vray 1.49.01, Win7 64 bit
      I understand that there is a limit of 1024x1024 pixels for importing image textures ,
      and it doesn't matter if i have high resolution texture,Sketchup downgrades image resolution to a maximum 1024 pixels.
      When i turn on "Use Maximum texture size", it can improves image visibility just on screen depends on my graphic card, but when exporting Jpeg format image,the texture image appears blur.
      Anyone knows when i use Vray for SU,my render output suffers from this image textures limitation up to 1024x1024 pixels?
      Thank to all in advance
        Ridie1389
        In my case at least, even though SketchUp itself limits the resolution, the VRay rendering engine doesn't. I usually render at 2048x1536, and I use one non-repeating texture on the floors of my models, and they come out crystal clear.
        I couldn't understand if aren't sure if it will be limited or that you know its limited and trying to figure out why. So I answered to the former.
          amorp
          Thank you very much for reply,
          i am not sure if it will be limited if i use textures greater resolution than 1024 pixels
