    VRay OpenEXR not saving
    renderpluginsextensions
    2 Posts 2 Posters 340 Views 2 Watching
    • E
      erik411
      So I am trying to render my fairly large model (80 MB) at a higher resolution and save as an EXR. However, when I hit render, sketchup says it is processing the scene for a few minutes and then disappears as if it was finished. I go to look where I saved it and its not there. Done this four times and I dont know why its not working.
      • dkendigD
        dkendig
        On OSX there is an issue that requires you to specify the file extension. Aside from that, the only thing I can think of, is that the path specified either is located in a folder that doesn't exist, or there is an permissions issue preventing you from saving anything there. Choose another path and try again. Use a small scene with just a box or something.
        Devin Kendig
        Developer
