    Double line or Offset
    layout
    7 Posts 5 Posters 1.9k Views 5 Watching
      agrazdi
      Is there an easy way to draw double lines or is there an offset comand to use like in Sketchup ??
      • yorik1984Y Offline
        yorik1984
        Can you show examle what you want?
          No. Currently there's no option for drawing double lines nor for Offset. Both could be useful tools so perhaps you could make a feature request in the LayOut Wishes forum.
          In the meantime, maybe you could draw the lines in SketchUp, import them as a viewport, render in Vector and explode the viewport. It's a few steps but it could do the job.
            agrazdi
            Now i draw the offset line using grid snap at defined distance around the path desired.
            • RichardR Offline
              Richard
              Mate I'd turn gay for one of the developers if they would introduce an offset tool in LayOut, particularly handy when it comes to curves!
              BUILTBRAND.COM.AU
                ArCAD-UK
                Careful what you wish for Rich, you might have to accommodate the fillets & chamfer programmers as well! ๐Ÿ˜ฒ ๐Ÿ˜†
                • RichardR Offline
                  Richard
                  Hmmm? You're right if all my wishes come true I'll be busy!
                  I retract my last post!
                  BUILTBRAND.COM.AU
