    Curve Stitcher not stitching correctly
    9 Posts 3 Posters 995 Views 3 Watching
    • B
      bhbarchitects
      Hi All
      Sorry this must have been asked before, but cannot find the answer.
      Why does curve stitcher sometimes not make a smooth face between two curves.
      Every time i make the window left side stitches fine right side goes crazy.
      Tried exploding the curve and re welding same result.
      left side fine, right weird!!
      • cottyC
        cotty
        I would use Curviloft in this case...
        edit: added image
        my SketchUp gallery
          How did you draw the curves? It looks to me as if one might have been drawn in a different direction than the other.
          I agree with Cotty. I would use Curviloft.
          • B
            bhbarchitects
            Dave
            Interesting I thought it may have been something with direction path was draw.
            Curviloft is awesome but how do i alter the direction of a path so it works?
              You shouldn't need to change the direction of a curve but you can play with the Vx Matching if needed. It's in the toolbar that opens when you are using Curviloft.
              To be honest, you shouldn't really need a plugin to draw these openings. They can be made with the native tools.
              • B
                bhbarchitects
                Dave thanks for the info
                Sandbox results are not as smooth as curve stitch as it stitches the curves together differently and i would rather not do it manually as there are lots of different windows all different dimensions.
                So what native tool am i missing?
                • cottyC
                  cotty
                  Maybe you should try to create them without the gap (e.g. pushpull and scale the pulled face before deleting it).
                  my SketchUp gallery
                  • B
                    bhbarchitects
                    Dave
                    Following your info if i am careful to draw paths in the same direction it works fine.
                    Thank you
                      I wasn't suggesting Sandbox at all. I described the process in one of your previous posts and Cotty has done described it as well. Plugins are great but you do yourself a disservice if you choose to use them instead of learning how the native tools work.
                      It's good you got the path direction sorted.
